A heritage property in the Adirondacks maximizes indoor-outdoor living space.
16 ga. brads would have a tendency to pull through the soffit (Hardi or otherwise)
if it was a narrow (under 12") and trapped by a plowed fascia (at roof edge) and and a freeze board (at the wall) you might get a way with it, but in that case probably not needed anyway.
I use a coil siding nailer now with ring shanks. Prior to that I used a framing nailer with 2 3/8" ring shanks. If I miss the framing it will blow right through, so I try to be careful.
Thanks Bill. Actually the fascia is plowed and there will be a freeze board so I guess i'm okay? The soffit is about 20" wide.
I always use narrow crown staples.
On the same track is there a trick for nailing aluminum fascia so that it doesnt ripple? Seems the temp. differential during course of the day can make go from taut to ripples.It was pretty hot when we nailed the stuff im talking about.
Yes there is.
I have found that if you face nail you have lots of ripples. The way around this is to put the facia up, behind the drip edge and nail the underneath portion to the soffit. Every 2-4' is sufficient. Then only one nail in the face at the overlap!
Thanks. I don't have a crown stapler so i'm stuck with the 16ga. Is galvy nails or staples a must for Hardi?
Now you've got an excuse to buy a stapler. See how things work out?I've found 18ga staples sometimes have a hard time penetrating hardi products though. My 16 ga Bostitch medium crown would have no trouble, and it has adjustable depth, but the staples I have are just electro galvanized, which just possibly might be OK if they were not exposed.I think I would just predrill and nail it up with hot dip galvanized or stainless nails myself.
galvy nails or staples a must for Hardi?>>>>>>>>>>>>>>>>>>>
Yep!
Staples like the Bostitch narrow crown are 18ga. and IMO too light to use for hardie. And the electro galv is basically useless for cementitious work.
You want Stainless or Monel ( Floyd Tools sells the stainless fastners I use) but that all said, I'd not use 16 ga nails either unless stainless.
I refuse to use fastners that can stain or not out last the material being put up.
If I can't find gunable nails that work, the palm nailer or hammer comes out to do it right.Spheramid Enterprises Architectural Woodworks
Thanks Guys. I'll see how it goes. Is it just my neck of the woods or do your lumber/hardware suppliers look at you funny when you ask for stainless nails also?
Just order them and avoid the laughter and ridicule at the yahd. They don't stock them here.
16 ga straight brads here, they have angled too for those few angled guns. http://www.floydtool.com/brad_nail.htm#sp16
They don't look at me funny, but then I don't ask, buy them online>G<
Will do .
If you must use 16 ga nails cross nail it by driving 2 nails close together at opposing angles. 20" wide is quite heavy and those 16 ga nails heads aren't very big at all. Narrow crown staplers are pretty cheap - you can get a half decient one (depth of drive adjustment) for around $100. They are great for fastening most types of thin sheet material, and they hold really well.
