16″ OC vs 24″ OC Exterior Walls
bozobozo | Posted in Construction Techniques on November 22, 2011 03:09am
I am in the final stages of designing a new home.  We have begun to talk to builders and several of them have expressed a pretty severe reaction to my desire for 24″ OC 2×6 exterior walls.  They are saying that they will not build that way due to problems with drywall issues.  I am specifying 5/8″ drywall on the exterior walls and the walls will be panelized by the same company building the floor and roof trusses.  Am I asking for trouble by sticking with my plans.  I want to do it this way for insulation purposes.
  1. florida | Nov 22, 2011 05:17pm | #1
    I can't imagine why any builder would have a problem with it. 2 x 6" exterior walls. 24 oc aren't anything new. However, if it were my house I'd go with 16" oc and install foam board on the outside of the walls walls instead. You aren't going to get much bang for your buck your way. .
  2. glacierfergus | Nov 22, 2011 05:54pm | #2
    When i built my house I looked into doing 24" on center.  Some building materials and siding will allow 24 OC, but many specify 16 OC maximum.  I wound up doing 2x6, 16 OC, and 3/4 inch foil faced poylcio on the outside.  The foam on the outside breaks the thermal bridge of the studs, and i didn't have to worry about what I planned to use for siding or interior finishing now or in the future... You would have plenty of structural strength with 24 OC, but you may live to regret your decision when you start looking at materials and what you really want isn't rated for 24 oc framing.
    kenora | Nov 23, 2011 02:54pm | #3
    I'm not sure where you are but 2x6 24" o/c is pretty routine here (Winnipeg, Canada). I just built a house using that AND 2" of ridgid foam on the exterior to break the thermal bridge (I got R30 (approx) in the wall) as a result and saved a bunch of time framing. No magic to it.
    If your builder won't do it have him/her wake up and see its 2011 :)
    If you are looking for specific and informed advice on building an energy eff home have a lok at greenbuildingtalk dot com
    1. bozobozo | Nov 23, 2011 07:05pm | #4
      I talked to my drywall sub today and we are going to stay with the 24" OC and 5/8 drywall.
        BossHog | Nov 24, 2011 07:51am | #5
        Don't forget to account for the extra thickness of the drywall when you order windows and doors.
Start your subscription today and save up to 81%
