3/8″ DW span
hammer | Posted in General Discussion on February 15, 2006 02:35am
It’s been years since I used 3/8″ dry wall. I remembered it didn’t have a taper.I used a sheet the other day to aid a plaster repair and quess what this stuff has a tapered edge. When did that happen? I have to use this more.
I was wondering what this stuff will span? It appears very dense. Could it span 2-0 on a horizontal?
  1. DonCanDo | Feb 15, 2006 04:09am | #1
    Take a look at the USG (sheetrock) installation guide here:
    http://www.usg.com/USG_Marketing_Content/usg.com/web_files/Documents/Installation_and_Appl_Guides/Shtrkgypsum_panel_and_joint_treatment-installation_guide.pdf
    According to them, no, you can not span 24".
    I was actually surprised to learn that when greenboard is installed on a ceiling with joists 16" OC, they want you to use the 5/8" sheets.  I used 1/2", but I haven't had any problems with sagging so I guess their recommendations are somewhat conservative.
    -Don
    MarkH | Feb 15, 2006 04:10am | #2
    It can.  But I think it's too thin by itself for a wall.
    If you're talking ceilings, I wouldn't think its a good idea on 16", but I have seen it done, and didn't noice any sagging.
    Edited 2/14/2006 8:14 pm ET by MarkH
  3. hammer | Feb 15, 2006 05:54pm | #3
    Thanks guys for the info.
    I'm acually looking at covering plaster walls. The walls had panelling ( 70' remodel) glued to the plaster. Well most of the finish plaster and then some came off with the panelling. Easier to cover than patch. The 3/8" should work better with jamb extensions etc.
    The ceiling is another story. This house has NO insulation. Looking at reframming over plaster. Get at least a R~13. Will go 16 oc and use the 3/8"
    Thanks again
