3 X 14 Joist Hangers
anwalt | Posted in General Discussion on September 19, 2006 05:59am
I have a small DIY project that would go so much easier if I could locate 3 X 14 joist hangers (actually 3 1/4 or 3 1/2 X 14).
My local Menard and Lowes has nothing close to 3 X 14.   I searched the internet.  Simpson has a hanger close  3 1/2 X 10, 12, 14  and lots of specs, but no sources.   I found no other location on the internet.
The project needs only 10 hangers.
I welcome any suggestions as to where I may purchase 10 hangers 3 X 14.
Thank you in advance
anwalt
    bobl | Sep 19, 2006 06:05pm | #1
    WAG
    go to a local metal shop and have them made up.
    bobl          Volo, non valeo
    Baloney detecter    WFR
    BossHog | Sep 19, 2006 06:06pm | #2
    Try a truss plant. If they build floor trusses, they likely carry a Simpson HHUS410 or THA422, or something similar with a 3.5" seat.
    What do you get when you cross a zebra with an ape man for all eternity?
    Tarzan Stripes Forever.
    1. anwalt | Sep 20, 2006 01:40am | #8
      Boss,
      Using these numbers I was able to locate a source for Simpson THA413 that will work great.
      As for the not so small project thoughts, yes, it is a small project.  I wish to install a ceiling as a first step to winterizing my garage.  It has a pitched roof.  The 2 X 8's tension members are installed on every third rafter (16 oc).   I need attachment locations for the ceiling drywall, so I will add 2 X 8s.  However because the roof is on and with other obstructions, such as the garage door apparatus, full length 2 X 8's will not go in easily.
      Parallel to the ridge, in the center is a strongback of 2 X 6.  My thought is to attach joist hangers to the strong back (6 inches) and join 2 short 2 X 8s below (8 inches).  I need the 3 inch width to attach a 4 foot splice to the 2 X 8's.   (6 + 8 = 14)
      The garage stood 30 years before I bought it.  So structurally I need to support the drywall and blown in cellulose above.
      Thanks to those who responded, and to those who were concerned about the size of the project.
      anwalt
        BossHog | Sep 20, 2006 02:42am | #9
        Without a lot more info I'm not sure that what you're doing is structurally sound. But it doesn't really sound like it.Before you go too far, I'd suggest having your idea reviewed by someone with some structural knowledge. Or sketch it up and post it here and you'll get some feedback.
        A waist is a terrible thing to mind.
    xxPaulCPxx | Sep 19, 2006 07:01pm | #3
    The hardware store of lumber yard that carries Simpson should be able to easily special order what your need.
    Also a CRX fanatic!
  4. GHR | Sep 19, 2006 10:20pm | #4
    A project that needs 3x14 joists is not a small project.
      BossHog | Sep 20, 2006 01:29am | #7
      Have you ever considered giving out some useful advice, instead of your typical drivel?
      Your village just called. They're missing their idiot.
      1. GHR | Sep 20, 2006 03:04am | #10
        Looks like my comments were the best - they brought out the "find an engineer" response.
  5. xosder11 | Sep 19, 2006 10:43pm | #5
    Maybe explain the application for us a little. Are these manufactured I-joists with a 3" flange? Are you hanging doubled conventional joists? Why the 14" depth. You may have other options available, but tell us more. If it's I-joists ask the manufacturer.
  6. Framer | Sep 19, 2006 11:15pm | #6
    As GHR mentioned, a 14" joist is not a small project. Do you have a set of plans? Where did you get 3x14 information joist from?
    Ask any lumberyard for a 3-1/2"x14" I-joists hanger and they will know what you mean. They get get them any time.
    What will these 3x14" beams be holding up?
    Are they doubles that will be holding up other joists?
    If so, those regular I-joist hangers might not be strong enough. You might have to get the heavy duty face-mount hangers like an HGUS414.
    Joe Carola
    Edited 9/19/2006 4:50 pm ET by Framer
  7. davidmeiland | Sep 20, 2006 04:49am | #11
    Sounds like you found what you need, but FWIW I had an occasion to check out the cost of special order joist hangers from Simpson, sized a little smaller than what you need, and they were about $12 each including whatever ridiculous penalty my local yard was planning on imposing. Simpson will custom-make pretty much anything you need, which is easy for them since they have plants full of automated fabrication equipment. Your hangers would only require a couple of keystrokes them.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
