http://www.cnn.com/2015/04/22/world/gallery/hatton-garden-heist/index.html
The thieves who broke into that vault in England and stole $300 million worth of gems needed to bore a10x18 inch hole through 20 inches of concrete. Probably not done with an HD RIDGID hammer drill.
Dan
Hilti
Looks like rats
You're right.
I've heard NYC rats do this all the time...in just minutes.
They are dead straight which makes me think it was somehow mounted as a horizontal boring machine
yeah.. I can't see whatever bored that being a hand held tool.
Also wonder how they managed to miss any steel.
billy posted a pix of the tool on bt3 - big cup drill
Small? More like "Routine"
Looks like a typical job for any concrete core drilling firm.
Such firms mount the drill in a sort of 'drill press,' that mounts to the wall with as few as a single 1/2" bolt.
The rig uses a diamond-tipped core drill bit (think 'big toothless hole saw') that operates witout hammering or vibration. Often use with a water flush, they can also be used dry. Such bits go for about $100 per inch of diameter. The bits have no problems cutting through rebar - and I think I see a bar in the middle of the pic.
Such equipment is readily available, both new and used. Plus, coring companies are as vulnerable to burglary as any other business.
I estimate that the core drilling took about 6 hours.
Yeah, if you read the article (link at the start of my post) the story indicates they did the job in probably two sessions of 8-10 hours each, including time required to cut through some steel doors, and time to actually raid the safe deposit boxes.
I don't see any holes for the attachment bolts, but they might be off the edge of the picture, or perhaps they secured the rig some other way. Apparently the rig was a Hilti DD350.
