In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
acrylic shower pan rocks
dockelly | Posted in General Discussion on October 17, 2005 02:33am
Hi all,
I have gutted my bathroom and will be replaceing the fiberglass shower pan with an acrylic one. The old pan sat directly on the plywood. I did a dry fit and the pan rocks back and forth. I’ve searched the archives and find several different approaches. Some say use mortar mix, some expanding foam etc. What are your experiences with this problem?
Thanks in advance,
Kevin
  1. Scooter1 | Oct 17, 2005 02:37am | #1
    Foam won't have a lot of compressive strength. I'd buy a $5 bag of drypack and set it in that. Don't stand in the pan to set it--otherwise you're setting yourself up for flexing at that point.
    Regards,
    Scooter
    "I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
  2. davidmeiland | Oct 17, 2005 03:14am | #2
    The absolute best thing I have ever used for this is Structo-Lite plaster. It has the texture of thick cottage cheese when mixed, and is easy enough to compress so that you can just set the pan in it and push it down a little. Do not stand in it, as mentioned above. It sets up quickly and sets up rock hard.
    Study the bottom of your pan before deciding how to lay out the plaster. Sometimes a thin coat over the floor works best. The last one I did I put out a couple of dozen blobs, like baking cookies.
    Mortar is way too hard to compress, in my opinion. It's for setting things like rocks and concrete blocks.
    1. dockelly | Oct 17, 2005 03:17am | #3
      So your saying to have several indivdual contact points, not a "soup" of the stuff with contact across the entire underside of the pan?
      1. FastEddie | Oct 17, 2005 05:53am | #4
        There might be instructions from the manufacturrer as to exactly where to place the blobs.  But if not, put a blob about every 4-6" apart.  The blobs should be about the size of a tennis ball.  Then when the pan is put in place, it will squish down the blobs as far as needed.  The space between the blobs allows the excess to squeeze out.
Forming Foundation Walls
In the first episode of FHB House Kansas, Travis and Joe of Catalyst Construction walk through details of their foundation walls.
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
