Adhesive ceramic tile to pvc tub surroun
I would stay away from contact cement for that project. It’s pretty unforgiving stuff to work with if you make a mistake. I think thinset would work fine. We put up some corian (Swanstone) surrounds using screws and Liquid Nails, and it seemed to work fine. The key is to get some 1×2 and cardboard/plywood scraps to put pressure on the surround so the glue can cure properly. If the ceramic tile is fastened properly, it should work fine.
