I’m hoping some of you guys are online. We’re getting ready to buy lumber for a shed, and we need opinions.
We have a 11.5’x16′ concrete slab that has a little 8’x8′ slab “addition” on one end (long story!). Planning to build a main shed over the large section with a smaller shed over the 8×8 section – all as one building. The small shed will either turn into a sauna or a little garage for a motorcycle. The larger building will be a workshop area with a loft. Both buildings will have cathedral ceilings with a regular gable roof – large beam with bird’s mouth cut rafters at a 12/12 pitch – like the old days before trusses. The weight of the loft will be supported by the walls, not the roof.
Here’s my question: How large should the ridge beam be that spans the 16′ with NO center support (like a center post) and how large should the beam be that spans the 8′ section? The local truss company wants to sell us a 1 3/4″ beam by 14″ for the large section at a cost of $200. The local lumberyard suggests an LVL engineered beam that’s 1 3/4″ x 11 3/4″ for about $70. The truss works is notorious for “overbuilding”, so we don’t exactly trust their quote of what we need, but we don’t want a sagging roof, either. As for the ridge beam on the 8′ section, we’ve been told that a 2″x8″ would do, but we’re thinking a 2″x10″ would be better. We are in NW Wisconsin, and we do have a snow load to consider, plus the roof will be 50 year architectural shingles that match the cabin.
Suggestions appreciated!
With what you have described, the floor joists for the loft will act as rafter ties and this is then not a ridge beam, but simply a ridge board and could be a 1x12
