Thanks for checking this post. My present client wants kitchen island with sufficient counter overhang to accomodate bar stool seated diners. Client also doesn’t want supporting brackets, but could relent, I suppose.
Client is also sold on Wilsonart or some varient. I would appreciate advice concerning best substrait or combinations therof. Thankyou
Mike Guertin explains how Pella Steady Set windows are revolutionizing the glazing game and provides a helpful installation tutorial.
George, I think I would use a bottom layer of plywood and a top layer of particle board, groove and plough the underside of the plywood (grooving slightly into the particle board) and inset 1" x 1" angle iron into the cantilevered portion, extending 1/3 cantilevered dimension into supported portion. I would do this at each end of the cantelever and as needed in between. I would fasten the angle with screws and epoxy, drilling several holes in angle to allow better purchase by epoxy. On further thought, I would check with Wilsonart as to the recommended substrate to bond their product to but would use the same reinforced sandwich concept.
*Are we talking laminate or solid surface? WilsonArt makes both and I would handle each differently.
*Ken and Don, thanks for replying. My client wants a solid surface material and is discussing Wilsonart because it is less expensive than Corian.
*Wislonart will have acceptable instalation specifications available; it's pretty important to stay close to these for warranty purposes. A welded frame of steel channel is common,extendending back and fastened to the tops of the cabinets. It is hidden by the drop edge of the counter.
*Thank, guys, for the input. The following question could be answered by calling a distributor Monday am, but I would like to find out if anyone knows whether Wilsonart 1/4" solid surface has to be installed by authorized installer to maintain warrantee
*George, wilson art laminate is my preferred product unless a client stipulates another. Thier solid surface product is called Gibralter, and yes they require a certified fabricator/installer to warrenty the product.there in lies the catch 22. You can't certify untill you attend one of thier seminars, or do at least 3 jobs with a certified fabricator. The seminars are infrequent and I am kind of hard headed about giving up my sell to another guy, when I know he is going to cut my price because he knows I marked it up to make a few bucks on his install. (boy,was that run on)Maybe your Wilsonart dealer is a little moore understanding or flexible than mine. At any rate the up side of Wilsonart is that most of the solid surface stuff has a matching laminate. LOLDave
Thanks for checking this post. My present client wants kitchen island with sufficient counter overhang to accomodate bar stool seated diners. Client also doesn't want supporting brackets, but could relent, I suppose.
