In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Aesthetic question: Chair rail
emaxxman | Posted in Construction Techniques on April 15, 2004 06:47am
Should a chair rail be:
1) proud of the door casing, i.e. protrude further from the wall than the door casing
2) flush with the door casing
3) below the depth of the door casing
I guess in the end it’s a matter of personal taste.  I was just wondering if there was a rule of thumb that most people follow.  I just installed a chair rail and it is almost flush (slightly thinner than the casing) and I’m not sure if it looks right or not.
  1. John7 | Apr 15, 2004 11:15pm | #1
    As a rule horizontal trim pieces do not exceed the depth of the vertical trim. Unless you plan on terminating the vertical trim on the horizontal (i.e. window casing on a window sill). After this rule it's all about taste....good luck
    p.s. in your specific case thicker casing(or a back band) might do the trick.
    john7
  2. andybuildz | Apr 16, 2004 01:45am | #2
    To me it should all meld together but if in fact you can come up with a design that "far" exceeds the depth of the trim you can simply put returns on the chair rail to make it look as though it was most definatly the plan rather than "trying" to tie in.
    Some people want to combine a chair rail with the look of a shelf/chair rail.
    right.its up to you but consider one thing.....don't try and make it look like you figured out a a way to blend them together in order to create an esthetically pleasing job.
    Put it together ...IMO...as separate thoughts done in a craftsmans way and mind.
     I donno.I don't think I said that right.
    BE unique
                       andy
    My life is my passion!
    1. HeavyDuty | Apr 16, 2004 04:32am | #5
      Sounds ambiguous but it's all clear to me.
  3. steve | Apr 16, 2004 03:57am | #3
    chair rail is usually thicker than door casing, therefor i put a return into the wall at 45 degrees ie both mitre angles are 22 1/2
    looks sharp and easy to do
    caulking is not a piece of trim
    1. geob21 | Apr 16, 2004 04:07am | #4
      The rule of thumb is never beat your wife with a stick thicker then your thumb.
      What's that got to do with chair rail?
    2. Snort | Apr 16, 2004 04:33am | #6
      That sounds interesting. Got a pic? & how do you measure it? Don't worry, we can fix that later!
  4. HeavyDuty | Apr 16, 2004 04:39am | #7
    There is no hard and fast rules, it depends on the style of trim too. As long as you handle the juncture with the approach that Andy outlined, you'll be fine.
  5. Piffin | Apr 16, 2004 05:46am | #8
    For the best, I like to make it proud of the casing and return onto it.
The Fine Homebuilding Interview: Emily Mottram
A Maine architect speaks about Pretty Good House and biophilic design principles that adapt to all climates.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
