Does anybody have any info on the the kit for air nailers that uses compressed air from bottles used with paintball guns. where can i buy this kit?
I use an old propane tank pressurized to 125 psi. Good for a whole load of nails.
Let the debate and chicken little warnings start again!.
Acknowledge that purging correctly first is a must.
http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=79606.1
bobl Volo, non valeo
Baloney detecter WFR
"But when you're a kibbutzer and have no responsibility to decide the facts and apply the law, you can reach any conclusion you want because it doesn't matter." SHG
http://www.supplierpipeline.com/jacpac_mm.asp?products=y&workshop=y&jacmorr=y&jacpac=y
http://www.specialtytools.com/product_info.php?products_id=7742
I own one and posted about it here a few weeks ago. I need to write a follow up report but gotta run right now. Stay tuned, I may have info you'd find interesting. I try and get that done tonight.
PJ
Everything will be okay in the end. If it's not okay, it's not the end.
Let's try that again: http://forums.prospero.com/tp-breaktime/messages?msg=20001.6169
use a CO2 tank... will cost you $12 each time you swap it out... I've painted a whole car with 2 tanks... a tank, a small regulator & hose... and on a trim gun... who knows how long it will last if you have no leaks...
(same type tank as used for soft drink systems)
p
Where do you get it filled ? at painball field a fill should be about 3-4$ or you can get an adapter for filling your self for arounf 60$ and rent a large tank from Gas supply shop such as BOC http://www.boc-gases.com/products_and_services/by_product/carbon_dioxide/index.asp
