Hello everyone,
I have a home in Vermont with a 2 inch diameter hole in a joist between my garage and basement. There are about 10 romex cables including a 220v cable running through it. It lets in quite a bit of cool air (not to mention the risk of automobile exhaust) so I would like to seal it. I’ve been hesitant because of the electrical cables. Is there a product or technique that is safe and won’t harm the cables? Also, it would be nice if the seal could be removed if ever necessary to route cables, etc…
Thanks, Eric
It should have fire stop caulk. It is red and expensive..called intumescent I believe.
Save a few posts, fill in your Profile, we can help!
Hi, Eric,
Electrical supply houses carry duct seal, a play-dough like clay. Pack some in the hole from both sides. And then pack it around the hole and the cables. Keep it warm so you can mold it around the cables. The stuff is fairly inert and it won't hurt your hands to shape it. It will cut down on drafts and vermin. A field mouse needs only a little-bitty opening for ingress.
If you can't find any just use drywall joint compound. It dries fast and makes a good, safe seal.
Good luck.
Even though it's not fire resistant, you could just fill it with expanding foam. If you need to run more cables, just poke a hole in the foam. Since it's only 1-1/2" thick it should break out easily.
By code it should be filled with firestop caulk as was previously suggested.
Plaster is a bad idea.
Expandable foam will work but is not code approved.
The purpose of using firestop caulk is to prevent fire from advancing through framing penetrations. I have to firecaulk every framing penetration that leads from one structural component into another. I would assume your garage to house is considered in that regard.
For instance, a penetration from a wall cavity to the ceiling cavity is required to be caulked but the holes that lead from one stud bay in the wall to another in the wall are not considered. Room to room penetrations are considered.
The difference between stupidity and genius is that genius has its limits. -Albert Einstein
http://www.peteforgovernor.com
Of course, even flammable foam is better, fire-wise, than leaving the hole unplugged -- it's the airflow that's most important to prevent in a fire. Any of the other proposals should be fine fire-wise. Presumably the house pre-dates the requirement for firestop-rated caulk, and practically speaking either electrician's putty or drywall mud will outlast the wiring and framing in the event of a fire.
happy?
I would agree that anything to stop the draft is what is needed. I don't think you can get a rated assembly anyways with romex and fire caulk. Mike
I would have to assume that you COULD get a rated assmebly as the firecaulk is designed for penetrations with wire runs as well as other impliments. But I am just assuming and could be worng... which has happened to me once before.
Pete I wasn't referring to or directly challenging you, and my experience is in more commercial situations. It is my understanding that to have a rated penetration there can be no flex, romex, or cables and if those are present, they have to be run through a piece of hard pipe (conduit).
The solution you proposed would no doubt offer fire resistance and stop a draft situation, but an inspector may possibly question the assembly. Perhaps I am wrong about residential requirements Mike
Yep, just get some duct seal -- electrician's putty. It works like modeling clay, is safe on wiring, and fireproof.
happy?
That's a code difference between locales. Up here in Ontario you are required to vapour seal between an attached garage and a dwelling, but it is not considered a fire separation. So up here, canned foam would be all you'd need to do, provided you weren't worried about mice.
