Amateur needs help w/ stair trim detail
MrSQL | Posted in General Discussion on February 20, 2008 03:35am
I’m trimming out some stairs that intersect with an opening (see pic.).  Would you run the casing for the opening just to the finish stringer, or would you run it all the way to the floor?  My inclination is to stop the casing at the finished stringer right at the height of the stair tread (not seen in pic.)
All trim is American Black Walnut.
Eventually I’m planning to have walnut raised panel wainscoting on the walls.
Thanks,
Roger
Edited 2/19/2008 7:37 pm ET by MrSQL
  1. Riversong | Feb 20, 2008 04:00am | #1
    If by "finished stringer" you mean the skirt board, then I would butt the casing to the top edge of the skirt.  I don't know what you mean by "at the height of the stair tread" which would be below and inside of the skirt board.
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
    1. mathewson | Feb 20, 2008 04:39am | #2
      if you were looking from dining room to the rake side of the stair you might try something like this.
      MrSQL | Feb 20, 2008 06:41am | #3
      yes, I meant skirt board (I couldn't think of the name).  my reference to the height of the stair tread was because I was thinking that I could make the skirt board come up slightly above the tread [i.e. tread notched around stringer] with a 45 deg., then where the casing intersects it would be a scarf joint.
      That probably still doesn't make sense.
      Thanks for your advice.
      Roger
  2. gordsco | Feb 20, 2008 07:13am | #4
    Why eventually? Build for the raised panel now.
    Establish the height of your panels. If they finish at the same level as the top of your skirt board it does not matter where you stop the casing.
    If the casing is the same profile as your panel dividers, and the panel wall finishes above or below the skirt, you may want to run the casing, to the floor.
    If you are planning a panel wall, why do you need such a large skirtboard? Could the top rail of your panel wall and the skirtboard be the same size? That way the stair would be a incorporated into the panel wall.
    Gord
    Edited 2/20/2008 6:19 am by gordsco
  3. 43Billh | Feb 20, 2008 02:26pm | #5
    Don't have an answer for your trim detail, but those double doors are fantastic!
    Did you build them?
    Bill
  4. Piffin | Feb 20, 2008 02:57pm | #6
    I would probably make something like a plinth block tobbutt both pieces into. I would definitely not run the casing to the floor.
  5. Danno | Feb 20, 2008 04:52pm | #7
    I agree with what Gord said--would look more "planned" to run the casing to the top of the baseboard and make the casing the same width as panel dividers and unify the whole thing--put up the raised panel wainscoating now--at least that part of the wall that's under the skirt board.
Butt Joints in Decking
Avoid rot and split wood by positioning butt joints on a flat block with a dado for drainage.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
