I am building a deck. The footers are 36″ deep, 12″ wide and resting an “Big Foot” plastic footer forms at the base measuring 32″ across. I am using 6X6 posts to connect the footers to the joist and beam structure. Each post measures approximately 2 1/2 feet in length. One of the 6×6 posts missed the center of the footer form and is resting off center. The outer edge of the post is at the edge of the footer form. Is this a problem? Will the building inspector call me on this? If so, what is the best way to solve the problem? Bedud
The best tool for straight, splinter-free cuts is made even better without a cord.
No it's not a problem, you're still bearing on the post. And have a good day.
Gabe
Thanks, Gabe, for the encouraging reply. I didn't think it would be a problem but my township's building inspectors are real sticklers for detail. Just doing a little preventive maintenance so I might know what to expect when they come have a look. Thanks again for your input. Bedub
you would have to have a tremoundous load for it to be a bad situation.....2 hot tubs and 20 people and a truck maybee
Thanks, Frame Boss, for your encouraging words as well. No, there won't be 2 hot tubs or a truck. Maybe there might be 6-8 overweight people on this deck at a time. Most of the time, the people will be on the semi-circular terrazza that this deck will spill onto. Thanks again, Bedub
The only thing that could overload that footing, if it was poured plumb, is an inspector with such a big head that it would break his own neck..
"The first rule is to keep an untroubled spirit.
The second is to look things in the face and know them for what they are."
--Marcus Aurelius
For everyone who posted responses to my 12/31/02 question on off center footers, I just wanted to follow-up and say you were all correct. The building inspector didn't have a word to say about that, but he did commend me for doing a really great job. That felt good! Thanks for all your interest and feedback. BeDub
Good on you for remembering to tell the rest of the story.__________________________________________
http://www.quittintime.com/
