In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Ants Destroying Rigid Insulation
IdahoBob | Posted in Construction Techniques on August 28, 2009 05:32am
During a remodel a couple of years ago, I installed rigid poly-iso (the yellow stuff) insulation board over the tops of the exterior walls because there was no room to install R-38 batts and allow a air space above the insulation. Recently, I started to notice fine yellow dust on the deck below the soffits. Upon removing a soffit panel, I found an infestation of common black house ants (not carpenter ants). The little buggers had been tunneling away in the insulation board and setting up housekeeping there.
I removed the insulation board and sprayed with pesticide. Now I need suggestions of what replace the poly-iso with. I have seen references to borate treated insulation board but have not been able to find a source for it.
Has anyone had this problem and found a solution?  Location is Northern Idaho.
  1. JoeH | Aug 28, 2009 06:49am | #1
    ESP is treated.
    Joe H
  2. MHolladay | Aug 28, 2009 02:20pm | #2
    Idaho Bob,
    AFM R-Control expanded polystyrene (EPS) is borate-treated.
    AFM Corporation, 24000 West Highway 7, Excelsior, MN 55331
    800-255-0176
    http://www.r-control.com
  3. fingersandtoes | Aug 28, 2009 06:42pm | #3
    Are you sure they are what you call common black house ants? Carpenter ants come in several sizes within one nest and the look like ants and are common and black.
    You have a satellite nest in your rigid insulation and need to get rid of it or they will continue to destroy the insulation and any sheathing or framing that is in the way of their expansion plans. There have been some good discussions on how to do this with recommendations for various insecticides you can find though the advanced search. Good luck.
    1. IdahoBob | Aug 29, 2009 04:44am | #5
      I am pretty sure they are NOT carpenter ants.  We have those here as well but the are much larger than the ants I found.  All the ants in the two nests I found were the same size, betwenn 1/8" & 3/16" in length and they bite when they get on your skin.
      I have pulled down the soffitts and removed all of the poly-iso insulation.  Only two blocks had nests in them.
      I guess my next step will be to spray with some borate compound and then replace the insulation with treated EPS.
      1. fingersandtoes | Aug 29, 2009 11:58pm | #6
        That is encouraging news. Being able to get at the nests is a big plus. Sounds like your plan will deal with them for good. Beastly little insects.
        Edited 8/29/2009 4:59 pm ET by fingersandtoes
    Jeff_Clarke | Aug 29, 2009 03:34am | #4
    What fingersandtoes said.
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 487: Cedar Closets, Conditioning a Woodshop, and Regional Construction Jargon
  • Podcast 487: Members-only Aftershow
  • Festool's Domino: Worth the Dough?
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
