Attaching Drywall to Hollowtile wall ?
| Posted in General Discussion on June 16, 2001 02:27am
Any ideas on attaching drywall to hollow tile walls? Have used Tapcon screws after drilling, and also used concrete nails. Both techniques hold the drywall fine but take a lot of time. I’m looking for a quicker method. would a Hilti type gun work ?
  1. Dave_Richeson | Jun 15, 2001 04:08am | #1
    Nathan,
    I have uesd the small case hardened nails used to fasten wall mold for ceiling grid. I glue the board and use just enough nails to hold it untill the glue sets. You nay still need to hit the mortar joints to get good holding power. Also the nails are not galvanized, so they may rust when coated with mud. They have small heads so there is not much holding power. Don't dimpel the board when you drive them in. Wait untill the glue has set an set them the next day.
    Dave
    1. Jeff_J._Buck | Jun 15, 2001 11:01pm | #2
      *I've had good luck attaching drywall to block walls in a similar fashion. I just use roofing nails, hammered into the mortar joints.....and make sure to use enough liquid nails to keep it there. Jeff
      1. Allyson_Stiles | Jun 15, 2001 11:04pm | #3
        *I use the the tension pins designed for ceiling wall mould. The only thing I do different from what's already been said is: I don't use liquid nails behind the sheet, I use drywall mud behind it. We've done alot of commercial work doing this and it has been very successful. Good luck.Billy
        1. Jeff_J._Buck | Jun 15, 2001 11:10pm | #4
          *I gotta find these "tension pins"......never seen them....I think. Everyone carry them, or do I gotta go to the ceiling tile place? Jeff
          1. Allyson_Stiles | Jun 15, 2001 11:13pm | #5
            *Any store that has commercial interiors, i.e. drywall, ceilings, sound board, steel studs, etc. has them. I've even seen SOME Home Depots carry them. Most lumber companies also carry them. They are gauranteed to be found in a drywall supply store. They great in block, mortar and concrete.Billy
          2. Dave_Richeson | Jun 16, 2001 02:27am | #6
            *Thanks for the name of those rascals Billy. I had a "brain lock" when I wrote that reply. I just went out and looked at my jar, and tension pins is what I called them.I hate "senior moments."Dave
  2. NATHAN_SPENCER | Jun 16, 2001 02:27am | #7
    Any ideas on attaching drywall to hollow tile walls? Have used Tapcon screws after drilling, and also used concrete nails. Both techniques hold the drywall fine but take a lot of time. I'm looking for a quicker method. would a Hilti type gun work ?
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
