Attic insulation upgrade
SailorMike | Posted in Energy, Heating & Insulation on October 14, 2005 11:38am
I’d like to upgrade the insulation in my attic to R50 – R60.
I currently have about 10″ of badly installed rock wool on 1/2 inch ordinary drywall ceiling nailed to trusses spaced on 24 inch centers.
I’ve found a couple of references that state that the weight of cellulose and rock wool will _at_some_level_ cause the ceiling to sag, and that therefore the only choice is fiberglass, which is difficult to install well around trusses.
As I intend to remove the rock wool to seal and install a vapor barrier, I’d be starting from scratch with new insulation.
My tentative plan is to use polyisocyanurate board in the thin areas near the eaves and under the crawl-way and then several courses of unfaced fiberglass batts everywhere else.
I’d rather use cellulose, but the weight problem sounds like a show-stopper. If it’s real and not fiberglass industry propaganda.
Or possibly to fill in the bottom 2x4s of the trusses with cellulose. then lay some sort of support system across the 2x4s to support another 15 inches of so of cellulose. Maybe lath and tyvek…
Or…
Any comments, ideas, humor will be appreciated.
  1. joeh | Oct 15, 2005 01:18am | #1
    Or possibly to fill in the bottom 2x4s of the trusses with cellulose. then lay some sort of support system across the 2x4s to support another 15 inches of so of cellulose. Maybe lath and tyvek...
    Sounds feasible, sounds cheapest, sounds easiest too.
    Joe H
  2. experienced | Oct 15, 2005 02:24am | #2
    There are two ways that moisture enters the attic from the house: (1) air leakage upward by stack or chimney effect (warm air rises) through unsealed areas and (2) moisture diffusion through permeable materials such as drywall. Air leakage is responsible for 98-99% of the moisture that enters the attic so seal the ceiling and don't worry about the other 1-2%....the attic venting will take care of that.
    Don't remove the rockwool to install a vapour barrier....it's a waste of a good material if there's no pest dung in it. Spread it around to be even and level. Airseal at the sealing level....all wiring, plumbing and other penetrations, check around chimney chase (if interior chimney) and seal with fireproof materials. Weatherstrip and insulate attic hatch. Consider adding bath fan/s venting to the exterior, not soffits, and controlled by hand crank/electronic timer.
    Blow lightweight fiberglass (cellulose is my favourite but in this case you need a light product)  over the rockwool. It will form around the trusses, etc as will cellulose.
  3. AndyEngel | Oct 15, 2005 02:29am | #3
    Interesting. My attic has 10 in. of cellulose and the drywall is staying up just fine. As it was dense packed below a plywood floor, its density is something between 3 lbs and 3.5 lbs per cubic foot. Blown loose, I think cellulose settles to something like 2.5 lbs per cubic foot. I've never heard of drywall not supporting cellulose.
    Also, as the other posters said, air seal, and leave the mineral wool.
    Andy Engel
    Senior editor, Fine Woodworking magazine
    Never try to teach a pig to sing. It wastes your time and annoys the pig.
    Other people can talk about how to expand the destiny of mankind. I just want to talk about how to fix a motorcycle. I think that what I have to say has more lasting value. --Robert M. Pirsig
    None of this matters in geological time.
    1. experienced | Oct 15, 2005 02:51am | #4
      In this case he mentions that the 1/2" drywall is fastened on 24' centers. I was being overly cautious with the ceiling. I stopped blowing fiberglass and went soley to cellulose in 1983.
      1. AndyEngel | Oct 15, 2005 04:57am | #5
        I missed the 2 ft. centers. Might be worth comparing the density of blown glass and blown paper. It's possible that there'd be enough weight to create a problem, but I don't know. Say you did a foot of cellulose, and it's at 2.5 lbs. per cubic foot. A 4x 8 sheet of drywall would hold 80 lbs. of cellulose then. Assuming 5 nails per truss, that's 25 nails per sheet. The drywall is what, 40 lbs? So there would be 25 nails holding 120 lbs. Round up to make the math easier, and each nail is responsible for 5 lbs. Seems doable, but it might bow the rock. I bet that USG or some other manufacturer addresses this problem.Andy Engel
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
