A couple of weeks ago I posted a question about Azek trim and I got the answers to my questions but the problem is I can’t find that thread in the search function. I’ve never used the stuff before now and I applied it as I would have with wood. The question I’m having is should I have left a 3/8″ gap around the edges of the vinyl windows for a caulk joint? I set a 1/4″ reveal on the edge of the vinyl window but I didn’t pin the Azek to the vinyl but pinned it to a 2x backer over the flange. I didn’t see anything in any literature for the Azek or the window about a gap and hope I didn’t screw it up.
Should I have made the trim 3/4″ wider than the window and caulked the 3/8″ gap?
BjR
Edited 11/5/2007 11:00 pm ET by BjR
Edited 11/5/2007 11:01 pm ET by BjR
Greetings BjR,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Thanks Rez.
BjR
Well, if I understand your question, I usually leave a gap for caulk, but nowhere near 3/8" -- more like 1/8"
That said, assuming you flashed properly, you shouldn't have too much of a problem. I'd go ahead and run a bead of caulk over joint with some good caulk, like PL poly.
Mike Hennessy
Pittsburgh, PA
!/8" gap is about what I left.
BjR
Well then, all's good. ;-)
Mike HennessyPittsburgh, PA
