In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Backprime old clapboard – Kilz or Oil ?
ClevelandEd | Posted in General Discussion on August 30, 2004 05:15am
I’ve ripped out a couple of interior walls down to the studs.  The clapboard is nailed directly to the studs.  No sheathing.  House was built in 1840.
I was going to use Kilz, based on responses I’d gotten here to sealing odors from mice that had been in the wall.  Today I am looking at the backside of the siding and it shows stong signs of past moisture.  Now I don’t  see how it could ever have gotten really that wet, so I am thinking it is from constant absorbption of humidity?  The wood is a bit soft with age too.  Shellac, aka Kilz, has a bad reputation in damp situations.
Edited 8/29/2004 10:18 pm ET by Cleveland_Ed
    AaronRosenthal | Aug 30, 2004 06:31am | #1
    I have not run into this problem around here (in 1840 the only things being built around here were cedar longhouses) but I think principals are the same.
    If there is no obvious way the water could get in from the outside area, then it migrated from the inside. I would think that in Ohio, your vapour barrier would be against the inside. I think you need to look at the siding and decide if you need to replace the punk areas. Once that determination has been made, my first choice, since I use it, is a good oil based undercoat, and for ease of use, sprayed on. Zinnser makes H2Oil primer which is a pain to clean but good for these kind of applications. That's if your local experts think that, in fact, it's a good idea to paint the inside of the walls. There is a product called "Deodoroc" which is fantastic against smells. You may have to Google it to find a web site.
    Then it's insulation: sprayed or bats, depending on which side of the fight you are on. Vapour barrier and don't let the drywallers cut it - watch them!
    Good luck!
    Quality repairs for your home.
    Aaron the Handyman
    Vancouver, Canada
    1. ClevelandEd | Aug 31, 2004 02:24am | #4
      I've decided, with a lot of help from your responses, that the moisture was from inside the room.  That side of the house gets no wind driven rain.  It has been a kitchen for a long time, and the moisture was probably condensing on the backside of the siding.  I'll now get a proper vapor barrier in place insteadof just the kraft paper on the batts.  Somehow I'll try to leave an airspace just in case I'm wrong about the moisture source.   The punk wood is not so soft as to need replacement.  I already used some kind of enzyme treatment to cut into the source of the odor.
      I see I was mistaken in thinking that Kilz and Zinnser were shellac products.  I'll try to buy one of them rather than just use the Benjamin Moore ext oil primer I have here.   I might even put a 2nd coat on the primer, a top coat to really seal it.  Thanks for your responses.
  2. BillBrennen | Aug 30, 2004 07:26am | #2
    Kilz is an oil-based primer. Kilz 2 is a latex. White pigmented shellac is sold by Zinsser under the name BIN.
    Look at bulk water ingress, drainage, and then vapor issues. A properly built house is not going to rot the siding from within, or by absorbing water from the air.
    Bill
  3. GreekRevivalGuy | Aug 30, 2004 07:46am | #3
    Here in western New York state I've owned a couple 19th-century houses (1820 and 1838) that have had plenty of water stains on the backside of the original clapboards.  I'm quite sure the water penetrated from the exterior ... during 160 years of wind-driven rain, small cracks and gaps in the siding, periods of less-than-perfect paint covering ... I think that's to be expected.
    The open wall cavity ... and those same small gaps and cracks .. allows periodic wetness to dry.  Unless you can guarantee zero water penetration, don't pack insulation up against the backside of the clapboards, even if you back-prime them.  Better, I think, to use rigid foam insulation on the interior of the studs.  Or figure a way of maintaining some airspace behind the clapboards.
    You mention that the wood seems "soft."  Soft and moist?  Soft and decayed?  There could be a greater moisture problem than I've experienced.  It could be the water in moist interior air condensing on cold exterior clapboards.  You'll be installing a proper moisture barrier on the interior side of the studs, right?  That should help solve that problem if it exists.
The Fine Homebuilding Interview: Emily Mottram
A Maine architect speaks about Pretty Good House and biophilic design principles that adapt to all climates.
  • Healthy Cash Flow Management
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
