Hi,
I made a bit of a cock up when I tiled my kitchen backsplash. I, for some reason, started the tile about 1/4″ above the countertop. In my own defence I hadn’t installed all of the countertops, so it wasn’t apparent how big the gap was until I fitted the countertops. Raising the countertop height is not an option due to it having to tie in with other cabinets. I think the gap is too big for caulk and I’m afraid the sanded grout would crack. Is it possible to mix the grout with something to make is a little less brittle and give it a minimal flex? Tops are laminate.
Mike
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
You could use a caulk on the 1/4" gap if you used a backer rod. You're right about the sanded grout cracking..............mine did - lol.
You can usually buy caulking to match your grout color.
If it's no more than 1/4" caulk should be fine.
We change the course of history,
everyday people like you and me
Hmmm...
I usually think of a cock up as a good thing
>>>>>>>>I usually think of a cock up as a good thingNot if it's your cellmate that's got it.
"Let's go to Memphis in the meantime, baby" - John Hiatt.
http://grantlogan.net/
personal experience?
GD&R"Sometimes when I consider what tremendous consequences come from little things, I am tempted to think -- there are no little things" - Bruce Barton
I laughed 'ttill I criedso long everybody, I sense a time out coming...
>>>>>personal experience?Maybe, maybe not. You wanna be the wife or the husband? The husband? OK. Come on over here and suck your wife's #$%@.
I've heard pregnancy can make one grumpy
Many tiles have trim pieces like 1/2" 1/4 round.
Some have thin accent pieces too. Buic
As someone noted about color caulking.
I have used sanded caulk by the same makers as the grout I was using.
"I'm here to chew bubble gum & kick azz, & I'm all out of bubble gum" Rowdy Roddy Piper
Forget the grout, you need moulding.
Kowboy
What's the size of the grout joints on the splash?A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
