Anyone have any bad experiences with Hardiplank or other cement/fiber siding? Is cedar/redwood better? We are in SE Iowa with all weather extremes.
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
If you put it up and finish it off according to the instructions it will still be there when the rest of your house has rotted away.
*Just finished about 25 squares on my new home, and while I didn't have a "bad" experience with it, it isn't quite as easy to work with. Aside from the obvious differences, (cutting, nailing, drilling etc.) the one thing I found is that it really magnifies any flaws in your framing. I routered let-ins(?) for my simpson straps in the 4x6's and then sheathed over them, and I'm glad I did. That stud that is bowed an eighth will look like an inch after you side the house. Be really anal when you go back and straightedge your walls. The stuff simply won't forgive shoddy framing.Also it goes a little slow 'til you get the hang of it. Myself and a helper were doing about 2-3 sq. a day.
Thanks for the input. What are your thoughts on the aesthetics of these products? Do they truly look like wood once painted and will they do so in ten years?
Looks better than any wood you can buy today. Use the finish products they recommend (Valspar) and you should get much better (compared to wood) performance. Check out this web site http://www.tamlyn.com for information about vinyl materials designed to work with cement fiber siding materials.
*I've recently stood five houses up with the stuff. It seems like it will stand the test of time. I'd rather work with LP siding because of the the longer lengths.We put it over 1/2" osb, and it semms to look fine. We don't make any special effort to straightedge the studs, but our studs are decent to begin with. Any obviously bad stuff is culled (about two studs per thousand).It's heavy and also brittle at or near 0 degrees F.I'm going to use some of it on my house.But I'd use almost anything.Blue
So I haven't used it yet, but I did think about the problems of the long walls so I put some bays on and that will work to break up the surface. So theres my smarty pants answer to the problem! However we'll see how it works out! I usually shingle my homes but I'll try anything once!
