balloon framing and vertical t & g siding
damunk | Posted in Construction Techniques on September 13, 2014 03:52am
Building 26′ x 26″ garage with 12′ balloon framed walls with attic floor at 9′ 6″ on a mortised ledger. Trying to eliminate using plywood sheathing and simply installing vertical siding on blocking every 24″. D you think i need diagonal bracing???
    Mike_Mahan | Sep 13, 2014 04:43pm | #1
    Only if you don't want it to collapse. Or you could block all the verticle edges of the t & g.
    1. damunk | Sep 13, 2014 06:08pm | #3
      Blocking for t & g
      By blocking vertical edges?  I was going to do blocking across entire structure (continuous) every 24" to provide nailer for vertical t & g siding. wondering if i also had to do diagonal bracing. Any experience with structural framing like this?
        Mike_Mahan | Sep 13, 2014 08:00pm | #7
        You need diagonal bracing. I was being facetious about the vertical blocking. Although if you use sheathing be sure to block all the panel edges. This isn't by any chance a pole building?
        1. damunk | Sep 13, 2014 08:08pm | #8
          Not a pole barn
          Regular balloon framed on foundation. Just trying to save some cash on the material. I'll look into the metal bracing.
  2. oops | Sep 13, 2014 06:00pm | #2
    sheathing vs no sheathing
    Is there any particular reason not to use sheathing?
    1. damunk | Sep 13, 2014 06:11pm | #4
      sheathing for t & g
      Last time i was at lumber yard 4 ply 1/2" CDX was $25.  This is a detached garage.
        MarkH | Sep 13, 2014 06:22pm | #5
        I would sheath it with something, even flakeboard would be better than nothing, but if you want t&g only you will have to use diagonal bracing.
        There are various methods to brace the building, the easiest is metal bracing sold for that purpose, but you can let in  or surface apply 1x4.
    deadnuts | Sep 13, 2014 07:33pm | #6
    Of course you do
    Of course you need diagonal bracing. However, you don't have to use sheathing to achieve shear wall bracing.
    There are less expensive options. Have you considered let in metal "T" section diagonal bracing? Install per an engineer's recommendation. I don't belive precriptive code outlnes installation requirements for meeting IRC shear wall bracing requirements with let in bracing (wood or steel).
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
