In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Bandsaw Rental – shaping 6x12s
cwc09 | Posted in Construction Techniques on November 2, 2008 07:49am
Not too long ago I put out a post about shaping the ends of some 6×12 cedear beams. Got a lot of good feedback from everyone here. Thank you.
The conclusion was that I would mark my end detail on the beam, remove the bulk of the waste with a bandsaw and then make the final detail cut with a router and template. I agree 100%. But I am having a hard time finding a portable bandsaw for rent with a minimum 5.5″ cutting capacity in the MD / DC area.
Does anyone know where I could rent one in this part of the country?
I saw the one for sale at TIMBERWOLFTOOLS.COM and that would be great but my partner shot it down when he saw it was at least $2200.00. And I agree because it probably won’t get any use after this.
Any other alternative methods / tools for removing waste prior to routing. Really not optimistic about using a sawzall, chainsaw, etc… Sloppy, inaccurate, control issues. Any ideas would be appreictaed.
Thanks.
  1. gb93433 | Nov 02, 2008 08:07pm | #1
    I do not think that anyone with a bandsaw would be too eager to rent it to anyone else. However, you might be able to get a millwork operation to do the work for you.
    1. cwc09 | Nov 02, 2008 08:33pm | #2
      Yeah, I'll have to do some research on the millwork option.
      My issue is that I originally planned on shaping one end of the beam off-site, taking it to the site and getting an exact measurement before shaping the other end. (Tne beams will sit on brick columns which have just been installed) This way I don't cut anything short if the real life dimensions are way different than the drawings. But it does require me to cut the other end on site. I did already check out the site and there have been some changeses from the drawings. I guess I could make templates for each beam. But this whole plan of action would make it tough to work a millwork operation into the mix.
      Maybe my original thought process is not efficient enough though. It probably would be better to build a template for each individual beam to reduce the amount of moving I have to do with these almost 200lb beams. Just cut the first few according to the templates, test fit and if everything goes smooth run with that technique. It's just a little risky with such high dollar stock and long lead times if I make a mistake and need to replace a piece that was cut short.
      Thanks for your feedback
    ToolFreakBlue | Nov 02, 2008 10:17pm | #3
    Could you use a "stationary" band saw on 4 swivel casters?
    Elevate the beam to the proper height and clamp them down. Then bring the "stationary" band saw into the work.
    Could pick up a used bandsaw of that type for $100 to $150 without looking too hard.
    TFB (Bill)
      Dreamcatcher | Nov 03, 2008 03:26am | #4
      Along similar lines, I was thinking he could just buy a small stationary bandsaw and use it upside down...that's basically all the timberframe bandsaws are.$2200 is FN nuts. I don't understand why anyone would pay that much...most of the timberframe tools are outrageously overpriced. For half that price, I could custom build you a portable bandsaw and still make hefty profit.GK
      1. davidmeiland | Nov 03, 2008 04:51am | #5
        Seriously? $1100? I'd like to order one.
          Dreamcatcher | Nov 03, 2008 05:09am | #7
          Are you kidding me!?!?
          I'm absolutely serious. I can and would build this for $1100.
    popawheelie | Nov 03, 2008 05:08am | #6
    There was a post a while back from someone with the same problem.
    He used a sawzall with a long blade.
    The guy on the other side had a crescent wrench on the blade so he could steer the blade on his side.
    The guy on the other side keeps everything going fine so you don't cut into or to far away from the line.
    If you aren't sure if it will work try a test piece. Draw your patern and try it.
    You won't lose anything except the price of a long sawzall blade and a few inches off your timber. They are a bit long anyway.
    observer | Nov 03, 2008 09:48am | #8
    You should be able to remove the bulk of the waste with careful work using a small chainsaw if the profile isn't overly complex. Clean it up as planned with the router.
  5. ANDYSZ2 | Nov 03, 2008 12:25pm | #9
    I try to sell a simple cut for that large a timber but if they have to have the curve details I layout the cut on both sides and figure where I can use my 10" circle saw to make partial cuts. Then I buy the stiffest recip blades and cut as much as I dare out of the scrap side.
    Then I like to use my belt sander with very agressive paper to finish out.It is hard to get perfect but the sander seals up the end grain and usually they are similar enough that nobody notices.
    ANDYSZ2
    WHY DO I HAVE TO EXPLAIN TO FRIENDS AND FAMILY THAT BEING A SOLE PROPRIETOR IS A REAL JOB?
    REMODELER/PUNCHOUT SPECIALIST
Find a Female Tradesperson With Matriarchy Build
With a goal of getting tools into the hands of more women, this new web service enables people to set up consultation calls with women and nonbinary pros on a variety of home-construction projects.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
