Basement Ventiliation
SamJenkins | Posted in Energy, Heating & Insulation on June 17, 2006 10:08am
Worried about possible break-in, my spouse had the basement windows boarded up.  Since this is the room that holds both our central air unit and our cat boxes, the change in ventiliation is noticeable.  What is the best way to correct this lack of ventilation?  Remove the boards/install an exhaust fan?  If I replaced the windows with glass blocks, would leaving the center vent open do the trick? Spouse thinks that using a pipe with a duct fan inside to exhaust basement would work.
  1. brownbagg | Jun 17, 2006 10:14pm | #1
    around here alot use a vented louves type windows board for hurricane protection.
  2. Danno | Jun 18, 2006 02:53am | #2
    Others will probably chime in, but I would caution you against using any kind of exhaust fan without providing "make up" air--replacing what the fan sucks out. If you don't, you will have a negative air pressure situation and furnaces may back draft and so on. (Maybe you don't have a furnace or water heater in basement?)
    1. SamJenkins | Jun 19, 2006 03:17am | #3
      Water heater is in basement - so something to consider.  I'm becoming more convinced the answer may be to remove the boards from the windows (and install gates on them for security).
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
