In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Bathroom remodel
MBaybut | Posted in Construction Techniques on June 3, 2005 03:47am
Hi,
I’m completely gutting out my bathroom and I have a couple of questions.
1) I decided to frame out my bathtub about 4″ away from the wall creating a small shelf. The tub is fastened to this frame. Should I be caulking the horizontal corner, where the shelf meets the wall, or grout it. I was confused because I suspect that there will be a little flex in the shelf as the tub is filled and emptied, also, should I be grouting first or caulking first?
2) The tub surround is tiled and extends out about 2″ from the tub sides.I want to install beadboard paneling around the rest of the bathroom. the BB is actual birch, not the cardboard stuff. Can I use MDF to trim it out, Inc baseboards or is this setup not advisable? I’ve seen it in a couple of magazines.
All advise appreciated.
Mike
    gdcarpenter | Jun 03, 2005 06:43pm | #1
    No grout, just caulk where wall meets horizontal tub surround.  I would never use MDF in a bath, one wiff of moisture and all your hard work is for naught.
    Let's not confuse the issue with facts!
    Sphere | Jun 03, 2005 06:51pm | #2
    BE certain to FILL the tub with water BEFORE you caulk it..makes all the difference in the world.
    The Morphine    s eems  to do no good at all..I'd run all the way if I would not fall...
  3. quicksilver | Jun 04, 2005 01:08am | #3
    I think I agree with the no grout comment above, although I've never applied this as a technique, On the other hand I've scraped out crappy grouting many times to caulk in new const. I also agree with the no mdf. Thats sound like a bad idea.
    JeffBuck | Jun 04, 2005 08:11am | #4
    grout vs. caulk.
    grout looks better ... caulk performs better.
    for customers, I caulk to avoid call backs ... my own bath ... it'd be a toss up.
    mdf ... small bath. It's out of the "wet zone" ... and "should" work ...
    but why risk it? What's the money difference gonna be?
    Not like you are pricing out a whole house trim job.
    spend the money on real wood and good paint and primer.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
  5. piko | Jun 04, 2005 08:17am | #5
    Is the tub used as a shower, too? What is the shelf made of? I've tiled a shelf beside an acrylic tub, and been back to fix it 3 times already, although I filled tub with water during instal (must be the 250lb customer getting in and out). slope said shelf slighly so water runs off. Use a damn good sealer all round, Use caulk where poss - and a tip here: if you have a special grout colour, mix it into clear caulk squirted from the tube, then squish (that's a technical word, right) it into the appropriate joints the best way you can. It will darken up to the colour you see when you normally mix grout with water, true, but other than blending 2 or 3 sorts of caulk to match, I see little alternative.
    Cheers
  6. WayneL5 | Jun 04, 2005 04:13pm | #6
    For the baseboard I'd use the extruded plastic (I believe it is polystyrene) stuff.  It will be completely unaffected by moisture.   Real wood would be more resistant than MDF, but the plastic stuff would be even better.  You could use real wood on for the rest of the trim.
    Lowe's has it around here.
Downsizing to a Cottage for Aging in Place
By subdividing this property, a family was able to build a smaller and more accessible cottage for aging in place.
  • Track Lighting for Functional Ambiance in Busy Spaces
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
