bathroom wall hung sink install
rick12 | Posted in Construction Techniques on February 14, 2007 05:39am
Hi all. My bathroom remodel. My plan is to install 19″ ceramic wall hung sink. To be installed over ceramic tile installed over green board. I know that I need a wood ledger board behind the rock to accept/hold the wood screws that secure the sinks’ wall bracket. Is it a better method to extend or build out a small portion of the wood ledger board to flush with the tile in order to accept the bracket screws directly instead of having to screw through the tile and rock to reach the ledger board? I was afraid that screwing the wall bracket directly over the ceramic tile might crack the tile and dig into or compromise the rock behind it loosening the brackets’ tight connection to the wall? Thanks for any and all comments.
  1. calvin | Feb 14, 2007 06:09am | #1
    If you could leave out a couple of tile where the layout says the bolts need to go and still be covered by the back of the sink, sure.
    Leave the tiles that you don't put in there in the linen closet for the poor bastard that gets hired to do something else.
    spot glue a couple wood shims the tile thickness in the blank spaces.
    http://www.quittintime.com/
    Edited 2/13/2007 10:10 pm ET by calvin
  2. woodroe | Feb 14, 2007 07:47am | #2
    If you are worried about crushing of the rock behind the tile, put a piece of cement board in that location. Also, make sure the wood backing is flush with the studs. This will prevent the hanger from cracking the tile as it is tightened.
    Lastly, forget the green board, use regular rock. Every inspector and drywall contractor I've asked has said the stuff shouldn't be used.
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
