In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Beam & Rafter Sizes for Snow Country?
JoeWood | Posted in Construction Techniques on October 18, 2006 02:11am
I know how to size joists and beams for decks (Span Tables) but I don’t really know how to size rafters and their beams, especially for snow loads! (I’m a SoCal boy, don’t know nuttin about snow! 🙂
I’d like to know if this structure will fly in Snow Country (Colarado)
Roof is a 6:12
The stock would be Clear Dry (19 %) western red cedar. The rafter span would be just under 6’ (walls are 12’ square), and I’d like to use 2×6 rafters and 2×8 hips. The rafters would overhang 2’8 (span of 2’ 6.5â€).
The beams would be made up from 2, full sized (2†nominal) 2x10s glued up together, after planning the beams would net out at 3.75†x 9.75â€.
Think this will fly under a bunch of Snow?
Is there an Online Calculator that I can use, where I can choose all these parameters, including wood species (wr cedar) to find these beam and rafter sizes?
I’ve included a nifty 3d PDF you can Rotate and Zoom on (You use those three Tools top left) if you have the Adobe Reader Version 7.0.7 or newer, or Adobe Acrobat http://www.adobe.com/products/acrobat/readstep2.html
appreciate any advice!
Edited 10/17/2006 8:00 pm by JoeWood
File format
  1. IdahoDon | Oct 18, 2006 04:29am | #1
    The snow load varies a great deal in snow country so you'll have to provide either a location or what the local codes are using for loads.  Permit?  Many Colorado counties are quite agressive when it comes to enforcing their codes.
    1. JoeWood | Oct 18, 2006 04:34am | #2
      This one's in Littleton, Colo. Don.
      http://www.mapquest.com/maps/map.adp?searchtype=address&country=US&addtohistory=&searchtab=home&formtype=address&popflag=0&latitude=&longitude=&name=&phone=&level=ZIP&cat=&address=&city=Littleton&state=CO&zipcode=80121(sorry, long URL!)The roof would be around 306 Sq feet, that's right at the size that would need a permit here in San Diego.
      1. IdahoDon | Oct 18, 2006 06:13am | #5
        Here's a long url for you!
        http://www.co.arapahoe.co.us/Departments/PW/documents/POLICY_SHEET_2003.pdf
        and another
        http://www.co.arapahoe.co.us/Departments/PW/documents/2003%20I-Code%20resolution.Web%20data.pdf
        The snow load for arapahoe county is only 30#
    IMERC | Oct 18, 2006 05:08am | #3
    which county...
    load rates vary from 60 to 120 pounds relative to county and location.....
    otherwise 50 will get by...
    120SF... good to go.. 120.1SF... permit required..
    WOW!!! What a Ride!
  3. Pierre1 | Oct 18, 2006 05:22am | #4
    In the southern part of the British Columbia Rockies, the snow load is figured on the basis of 125# per sq. ft. The roof must withstand heavy snowfall followed by warm weather or rain cycles. I understand that CO's snow is dryer, and stays dry, so your design loads may be less than 125#, unless your building is sited in a micro-climate that generates lots of warm snow.
    Remember to design and plan for roof avalanches:
    Around here, a 6:12 roof does not readily shed itself of snow. You need to go to 7:12 for that to happen naturally.
    Ask your county's bldg. dept. whether their design figures vary depending on the type or roofing used. Metal sheds readily - almost too readily if your parking spot, walkway or front door are under the drop zone. lol.  Shingles hang on to snow...until a shear plane forms on top of the first layer and new snow falls over that. The second layer will release much more readily than you would expect.
    Edit: just looked at your structure. Nice shapes and proportions. A hip roof tends to build up snow on the lee side of the prevailing winds. The windward side is usually scoured clean. This means that the roof loads will be unevenly distributed.
    Edited 10/17/2006 10:26 pm ET by Pierre1
  4. IdahoDon | Oct 18, 2006 06:30am | #6
    According to the load tables in my UBC code book (IRC as used by Arapahoe Co. )is out in the truck) it looks like you're in pretty good shape as far as span goes.  #2 2x6 western cedar 16" oc will span over 9', and at 24" oc something like 7' 6".
    One of those pdf files from the building department states that although a structure may fit the exemption from a building permit, it still needs department approval.  Who knows if that's enforced.  My guess is they would want to approve the plans/specs.
    The good news is, if they review your plans they will size any beams/posts.
    Hope that helps a little.
  5. GHR | Oct 18, 2006 04:57pm | #7
    "Clear Dry (19 %) western red cedar" is not a structural grade if lumber.
    You might see if your design falls under the prescriptive code or if you need engineering.
    If you need engineering, hire someone.
    1. JoeWood | Oct 18, 2006 08:19pm | #8
      Appreciate all the help with this Don!So, that UBC Code Book lists the spans for WRed? Gut feeling tells me that the rafters are fine. Guess there's no way to calculate laminated beams like these besides hiring an engineer.I have the people in Colorado checking on the snow loads, and if they do need a permit.So, does anyone know of any Online Calculators that give you the rafter and beam sizes need for any given span?
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
  • Podcast 485: Members-only Aftershow
  • Fastener System for Solving Deck Fascia Board Expansion
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
