In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Bedroom Egress Design
CloudHidden | Posted in General Discussion on April 19, 2004 05:44am
Design question.
We all know that sleeping rooms (that’s the code wording) need egress. But what would you say for a room that has mixed use? It’s an office, but provides overflow sleeping. Or an exercise or sewing room that you just know will get a regular or Murphy bed?
Would you make sure all of these mixed use rooms have full egress, which is not always practical, or label them as a “office” and let it be? In the case I’m wrestling with, it’s an older couple with no kids, so there’s definitely no regular occupant of any of the other rooms.
  1. DavidThomas | Apr 19, 2004 07:17pm | #1
    Jim, seems like if you are clear in all your drawings that it is an office, then egress requirements wouldn't apply.  Clearest if the room has no closet.
    Add a closet and label it office / "guest room" or "overflow sleeping" and it ought to have egress.
    It can be helpful to clarify to the clients what you can do (juggle spaces around, increase/decrease the overall size, etc) and what you can't do (spec a bedroom with only one way out).  You and the client are working together to comply wtih codes and have a liveable, affordable design.  Don't end up in a role of being the client's advocate to skirt the codes.
    I have put in rooms with occassional sleeping use that didn't meet egress requirements.  But there were windows to jump out of, even if a SCBA-equipped firefighter wouldn't have fit through that window.
    David Thomas   Overlooking Cook Inlet in Kenai, Alaska
  2. RalphWicklund | Apr 19, 2004 07:39pm | #2
    I would say, for your own peace of mind, if you know the room could be used as a sleeping room, plan for egress.
    Even if you could skirt the code issue what would you do and how would you feel if the older couple was stuck in that room and could not, under their own power, navigate through the rest of the house or to another room with egress, and the rescue personnel were hindered by, say, a clerestory or undersized window.
    A window sized up to meet the egress requirements should not be a challenge to provide in any room.
      CloudHidden | Apr 19, 2004 08:09pm | #3
      Except one completely interior. :)
      This started out like one of those puzzles where you move the pieces around till you have the picture you want. Well, I set the master suite, and the kitchen, and some other rooms, and put a theater room fully interior, and then I blinked and saw this one multi-use room left and just an interior space left for it. Damn. Small residence, so not lots of wiggle room, and all other exterior walls covered. Double damn. Guess I'll start over.
        BossHog | Apr 19, 2004 09:30pm | #4
        Sounds like quite a pickle.
        I'm no expert on codes, but couldn't the 2nd means of egress be a 2nd door instead of a window? Is that a possibility?Avoid suspicion: when your're walking through your neighbor's melon patch, don't tie your shoe. (Chinese proverb)
          CloudHidden | Apr 19, 2004 10:13pm | #5
          Unless I missed it, there's no exception for that.
          Just a dumb oversight by me. Caught it before showing anyone, so no harm, no foul. Just trying to think of an easy alternative, be/c the plan meets all their other needs really well. Maybe I'll show it to them and let them help choose what gets moved to make room for egress...
          1. DavidThomas | Apr 19, 2004 10:27pm | #6
            But in addition to egress, isn't there a fenestration requirement for bedrooms?  Or it that just a whole house thing?
            It better be just an occassional sleeping place - no windows makes for a pretty gloomy room.David Thomas   Overlooking Cook Inlet in Kenai, Alaska
            CloudHidden | Apr 19, 2004 10:45pm | #7
            Yeah, something like 8% of floorspace of a br has to be matched in glazing. But is a sleeping room a sleeping room if it's 99% office and 1% sleeping? 99.9? 80? I'll change it regardless...just kicking myself for missing something so obvious...
  3. buildboy | Apr 20, 2004 01:45am | #8
    Other issues aside, one thing to consider in new projects is that it can't be counted as a bedroom if it doesn't meet egress and other requirements. And as such could effect the "official" bed count for the house, and in-turn overall value of the home. But you probably already thought about that.
    As for egress windows, it's a bit of a sore subject with me. Not the concept, just the restrictivenes (is this a word?) of the requirements. Take for example a traditional double hung window. To meet egress requirments, the minimum size based on most manufacturers is in the 3 ft. wide by 5ft. tall range. This is absolutely rediculous! First it places the sill rediculously low such that you can't furnish in front of it. Second, it's a bit odd proportion. And last, it's way out of scale if you have small bedrooms.
    Sure you can get a 4x4 slider to work, but then sliders don't fit every architectural style.
    Sorry for the rant-and-rave, I just don't like being boxed-in to such a restriction...
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
