Thanks for the suggestions guys. Probably put this blog question in the wrong category. Sorry about that. Been awhile since I’ve been on this Web Site. I put the piece of door stop in front of the track and it clears just fine and you don’t see the track either. Basically picture framing out the doors. And yes, almost looks like a split jamb of sort. Even held a piece of shoe mould up to it but just doesn’t look right. I have the doors centered in the opening as good as you can get but still have the gap all the way around . Just looks cheesy. Have to do something here. I think you guys get the idea what I’m trying to do. Basically made a false jamb on top of the existing jamb then using the edge of the false jamb for the reveal for the casing on each side of the door and across the top as well. Thanks for your thoughts here. That’s why I got on this web site because I knew you guys would know about things like this. I trust your knowledge and skills because I figured you have done a lot of this type of work and know what will work and what won’t.
Thanks a lot fellas,
Terry
Terry, usually for continuity it's better to place your reply in the same thread as your original post.
Not that it's as easy to follow a thread here with this new 'software'................
thanks.
