After shutting off the water and draining the plumbings in my house last week for a vacation, I can’t seem to get all of the air out of the lines since I turned it back on. The water pressure is at 40 lbs. now rather than 55 lbs. prior to the shut down. How do I fix this? GW
Ventilation is considered standard practice, but not all building scientists think vents do much or agree on the best ventilation products.
IMO opinion, based on basic physics, air in the line shouldn't affect pressure.
Is this on city water or private well?
If well, do you have a bladder tank or single compartment?
Have you bled out the obscure horizontal pipes, such as those to the hose bibs?
Where are reading the pressure you report?
I agree with 4LORN1 -- air in the pipes shouldn't make any difference in pressure.
Yeah... it certainly shouldn't affect pressure. I wonder if there was scale buildup or soemthing else in the piping that was dislodged by the draining and refilling. And it can definitely take a while to bleed out the air after draining pipes. Open all the faucets at once and let everything run a while, then shut them off one at a time.
I ran the faucets when I got home today for about 10 minutes. All of the air is out. I had inadvertantly messed with the house valve up at the street next to the irrigation valve and I had turned the wrong valve to raise the pressure to the irrigation. I never reset the house valve before the trip. Thanks for the input all. GW
