In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
‘blind’ strain relief for NM
peedee | Posted in General Discussion on October 25, 2008 05:27am
I’m trying to find out if/ what is available as a strain-relief connector for NM cable when you don’t have access to both sides (int. and ext.) of the box being routed to (such as when entering a panel where you don’t want to pull off _all_ the drywall, or eq.). I’ve also seen just the push-in bushings used here and wonder if that’s acceptable (code or practice), though they don’t provide any strain-relief.
Thanks,
David
  1. pm22 | Oct 25, 2008 05:59am | #1
    Since you are fishing your NM cable through the wall, you do not need to fasten it to the studs or anything.
    You do not need "strain relief". Best would be to use a lock-nut type of connector.
    Since the KnockOuts are designed to be knocked in from the outside of the panel, and you only have access from the inside of the panel, drive a self-drilling sheet metal screw into the KO part way and pry the KO out. Do not touch the bare buses.
    ~Peter
Repairing Drywall After Removing Wallpaper
Use this process to sand and seal any damaged drywall before priming and painting.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
