Book Subjects You’d like Taunton to Pub.
I recently wrapped up a book on roofing with asphalt shingles and trying to nail down another subject with the Taunton Book department. What subjects do you think are missing from the Taunton Press offerings?
Would you have interest in a book on any of the following:
Wood Siding and Trim,
Kitchen Cabinet Layout and Installation,
Managing the Construction of Your Own Home / Remodeling Project
Installing Laminate and Engineered Wood Flooring
Designing Your Dream Home
Other Ideas?
Thanks,
Mike Guertin
Siding and trim - why limit it to wood? Hardibaord is coming on strong and manmade trim material is taking over a big percentage. Some jobs are mixed materials. We need to know more. Include rainscreen walls, backpriming, factory prefinished, types of nails.
engineered flooring- good choice
Designing you rdream... I like design but is there a void of ideas already published? Bring in something new or apply a new twist/viewpoint.
I'd like to see a coffee table book on stone facades and maybe an in depth book on types of stone and styles for laying them.
ANDYSZ2
Since FH has been mum on the subject of replacing windows on brick veneered houses....I guess I will have to consider buying a book on the subject. There was mention of this subject possibly being an upcoming article but no dice yet.
It should NOT be a review of replacement window choices.
Cover the nitty gritty on older window types that are encountered in brick homes and old masonry buildings and various ways to "fit" standard sized windows or fitting custom windows.
This should also cover the hopper style steel basement windows as well as steel casements that are difficult to remove.
Replacement window choices and installation should include commercial type awning and casements as well as fixed windows that are commonly seen in older commercial and public buildings that are upgraded.
Of all window replacement articles I've encountered in FH, I don't recall any that addressed brick veneered homes and the usual plaster walls/trims inside that needs to be dealt with.
Diagrams/pictures have mostly shown wood/vinyl sided houses.
This is probably wishful thinking ?
I'm still waiting for the article.
Alan
Can I vote twice for this one. Brick veneer is king in the GTA, but all they sell here are those pukey "replacement" windows that fit into the existing window frame..
Phill Giles
The Unionville Woodwright
Unionville, Ontario
Out of all mentioned, the two that haven't been beaten to death by the publishers are "siding" and "flooring."
From the commercial aspect, the flooring book would have more appeal to both builders and DIYers:
"Real wood" strip flooring, laminates, engineered ply, bamboo, even cork...
How to select a wood...wood movement, species hardness, species ability to take a stain, and traditional domestics vs imported exotics...ie, a chapter titled "How to Say 'NO' to Oak"...<g>
Acclimating wood to the site, underlayment (rosin vs #15 felt), joint layout, nail spacing...
Fancy crapola...patterns, borders, heck, even inlays...
Sanding, staining, urethane, oil, and wax finishes...prefinished vs finishing on-site...and a comparison of types of factory finishes and site finishes...
Nail down (tongue as well as face), staple down, glue down, floating...
Installing over an above-grade slab, below-grade slab, gypcrete slab...
Flooring over RFH: in-slab, gypcrete, sleepers, and staple-up...
And lastly...how not to commit suicide when you crack open the bundle and find 95% shorts...
A book dedicated to flashings would probably be a first! It's a subject that is mostly ignored in construction literature and, anyone who has done repairs or remodels for any length of time has certainly come across the results of badly done flashings or lack of same.
As a title subject, there is a lot of ground to plow, but it would be an invaluable aid to those of us in the field who are always looking to improve the appearance and longevity of the structures we build.
Taunton has the capability of mining information from experienced craftsmen (and women, of course) from across the country and overcoming some of the "regional differences" often discussed here would be helpful.
And you could start off with a treatise on step flashings, including a method Piffin described here recently (bending the metal on a diagonal).
Funning I have been meaning to ask a question about sources of information fire codes.
My comment was that there is plenty of information about flashing. You can't find a mag article or book on siding, windows, roofing, doors, etc that does not have at least some some discussion of flashing.
But a single book that covers all areas might be usefull.
But I don't know of any source that covers much on fire and safety? What materials can be used by themself? What has to be covered and what can it be covered by?
Instead of a book exclusively on flashing, perhaps that topic could be a large part of the content in a book called "Keeping Water Out". I want that book, especially if it's over 500 pages. What with mold being such a hot topic, this one could be very trendy.
-- J.S.
There is a book called that, or something really similar.....not too new, but pretty good...everything from French drains to flashing to ventilation.cabinetmaker/college instructor. Cape Breton, N.S
"Keeping Water Out" I like that. There are a lot of ways to flash a structure and, in this day and age, a lot of materials to do it with. What are the pitfalls of Al. vs. galvanized steel vs. copper vs. tin vs. some of the "synthetics" (like Moistop)? How to best preplan and coordinate with a sheetmetal shop.
And my wife would like to see a book about how to eliminate ants and cluster flies.
Mold mold mold mold
As I was reading these responses through, I was thinking, "Mold may just be THE issue of this decade for this industry but who would buy a book entitleds, MOLD & WHAT TO DO TO AVOID IT"
Limited potential sales would surely keep it from being published.
But you have tied it to a subject that several here have indicated wanting to see, Flashings!
A catchy title and this is a must (not musty) book to own!.
Piff
Where you been bro...they already figured out what to do with mold. Ever hear of penicillin? lol
Be well
Namaste'
AndyIt's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
Piffin
What about the Moisture Control put out by Building Science.
Haven't seen it. You got a link?.
Builder's Guide by EEBA is pretty good too, as a handbook with details drawn and studies referenced but this thread is less a list of good books and more a list of what Taunton could do well.
It's like diet books - nobody should stop at one. Own and study several.
Edited 10/18/2002 2:43:47 PM ET by piffin
Here is a link on the Building Science web page.
http://www.buildingscience.com/resources/books/default.htm
They don't show it, but I check and it EEBA does have it, and cheaper.
Also Taunton has republish two of the Builders Guides (cold and mixed), but I see that Building Science shows later addtions.
Joe Lstiburek's Builder's Guide series is now published by Taunton (amazing coup). Cold Climates ( http://taunton.com/store/pages/070504.asp) , Mixed climates.
mg
His books ought to be required reading for every builder in this country.
Different wwriters have different ways of approaching and explaining problems though so I'm sure someone else could hit another tack and connect with people on a different level..
There is a book that NAHB publishes on Mold. It doesn't deal with the details to avoid mold though. It's called "A Builder's Guide to Handling Mond Claims and Litigation" 24 pages. i think anyone here could have written it in 1 page, "Build it Right the First Time and You'll Never Worry About Mold Litigation"....
mg
Well, I'm having trouble finding a decent practical guide to adhesives. I know it's a topic too large for a single volume, but a subset book on practical construction adhesives, particularly the various epoxy, foam, 2-part, urathane, and hot-stuff adhesives, would be great.
Phill Giles
Unionville, Ontario
Mike, I don't know how well it would sell, but I guarantee that something is needed to explain communications between contractor/tradespeople and homeowners. It seems that a lot of troubles for both sides could be eliminated with better interactions. I imagine it to be a overgrown glossary of terms of all types. Maybe separate chapters on architechtural styles, materials descriptions, and so on. Too big? separate books then, but somebody should stop all the head nodding and start some real conversations. Because most of what is agreed to, is never really understood, in my opinion anyway.
Dan Call it "Words you have heard on a construcction sight, but were scared to ask"
That's a great idea. Constructioneese - English dictionary!
I have it I have it.....We can call it The Whole Earth Catologue!!!! It'd be so intense. We could list all and everything and be as thick as a phone book. Hmmm...Didnt someone already do that? Scratchin my head....
Be well
Namaste'
andyIt's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
Phill
Have you looked at the new adhesive book. Off the top of my head I don't remember the name or publisher. It might be Tauton. Been out about a year or 2.
Saw it - very superficial. I was thinking more about the West System booklet expanded to cover some of the other "exotic" adhesives.
Maybe it shouldn't be a book, maybe it should be a CD, with links to some of the major adhesive sellers ?.
Phill Giles
Unionville, Ontario
Mike
Odd roof framing and finishes. Such as curved gambrels, turrets / towers. More detail to these type of roofs connected to existing homes. I have yet to see even an article on curved gambrel roofs or turret construction in FH unless I missed it. I think people shy away from building them because they seem a bit complex which really isnt the case. When anyone passes my house I built with curved gambrels they always comment on how beautiful it looks....When I pass a house in my neighborhood that just put up a silo / turret addition I can't stop starring at it. Its so different, so inviting to my eye. Atypical roof / framing designs are fine but to add more interesting additions to meld the home together sure wakes up ones soul.
Be well
Namaste
Andy
Thin-shelled concrete d.......awww, never mind.
Roar!Half of good living is staying out of bad situations, the other half gets so complex I don't deal with it.
I never had a problem with character, people have been telling me I was one ever since I was a kid.
almost added that to my list of odd shaped roofs but figured I'd leave that up to you Cloud man.....funny that you chimed in shortley after I was thinking that..It's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
I had an opportunity to apprentice under an architect turned builder. On huge lesson I learned working with him on countless remodeling projects is making everything tie in ascetically. We were constantly analyzing what will be see from different angles and I was amazed how changing just a few dimensions can drastically alter the appearance or façade of a structure.
I see too many additions that were built purely for function forsaking form when just a little more planning would have made the addition flow with the original structure.
A book that discussed architectural form and how different details can drastically alter feel and appearance is a book I would buy from Taunton.
I wish I could find a book dedicated to urban remodeling and multifamily dwellings, though the small market for it would probably not be feasible. I second the thoughts of everyone who says "Dream Homes" have been done to death. Wooden siding and trim information is pretty plentiful as well, as parts of other books.
Kitchen Cabinet layout and installation is similarly covered in other places, but could probabaly use it's own tome, especially if the author would include the latest hinges, hardware, veneers and finishes. Allow me to digress on my BIGGEST CONSTRUCTION BOOK PET PEEVE! (drum roll, please....)
I work in Manhattan, one small part of remodels ranging from $100,000 to $20 million. The one thing they have all had in common is that none of them had colonial, country-kitchen type cabinets and finishes. I am so sick of opening up a book for some advice and seeing nothing but pictures taken in 1983 of an "updated" kitchen or bath built in 1952. No euro hinges, pocketed doors, under-counter fridges and wine coolers or plastics, but as many pages as you like of how to build panel doors and as many sample finishes as you want to see, as long as they are stains applied to pine, oak or cherry. I realize I am not representative of the majority, but I do see these newer designs spreading out across the country. Or maybe its just me...
I think the success of This Old House has perpetuated a myth that all quality building is somehow backward-looking. The reports you have received in this thread so far from the people in the trenches illustrates, I believe the desire of many involved in the industry to take advantage of the newest materials and knowledge out there. I would encourage you to write something that addresses those desires, that could not have been written ten or even five years ago. The books that could, have been.
I would also love to see a book about the "100 Mistakes You Should Try To Avoid When Going Out On Your Own". I am only on about #5 and just about at the end of my rope.
Congratulations on your last book and good luck on your next.
Don
I don't have a title to suggest, but I've seen about three here that I'd be willing to buy. Start with the coffee table book on stone!
ElleVic (got to make myself one of those tag lines if I keep hanging out here)
This may be more "masonry" than "carpentry," but I'd really love a book that details how to stucco a home...from beginning to end; including stucco recipes for exterior work and recipes for interior walls as well. I'd like to see the types of wire (chicken wire, expanded mesh, etc.) that are perferred by professionals, and would like to know how they handle specific flashing details (windows/doors) for stuccoing.
I'd like to see step by step techniques and the tools used to obtain different desired looks.
(Guess you can tell I'd really like to build me a new home and would like to have it stuccoed, rather than sided or bricked. ha! ha!)
Davo
I second the motion for a book on stucco. Be sure to include repairs to stucco, such as when they break into it for a re-pipe or to replace windows. Give good attention to moisture barrier and weep screed issues, too.
-- J.S.
I would also like to see a book on stucco... there's a lot more to it than some sand and cement. Luckily I have a Hungarian mason who knows everything...but taciturn only begins to describe him.
As a contractor, I would prefer books that focus less on how to perform a task and more on principles, detail drawings, and copious photographs of real life details. Many is the time I have combed through books looking for a particular way of doing something that I haven't seen yet...I don't really need to know how to do it, I just need the idea in the first place.
My ideal book on stucco:
Basic properties, types, mixes, etc.
Drawings of details...flashings, intersecting stucco and other materials, etc.
Pictures of different textures, colors, applications
Hundreds of pictures of real life stucco details
Frankly, I would love to see the same thing on just about any topic...fireplaces, porches, you name it.
I'd like to see a book on recipes for builders. Breakfasts, lunches, and dinners and snacks. Energizing formulars composed of tried and true foods by builders world wide. Betcha aint seen one of those! I have such great ideas.....lol
BE well
Namaste'
I would like to ask that a book be published dealing with the following....How a wife of a contractor survives endless years of remodeling an old farmhouse. If you guys can come up with a book for that it would be worth millions!!!!!!!!!!!!!!!!!!!!! I am sure there are many of us out here;_((((((((((((((((((((((((( Okay let me know when it will be for sell!Tamara
Thats a real easy one Tamara........you asked us to do it.. remember? ......so deal with it! Duh
Be well
Namaste
Andy
Edited 10/20/2002 4:09:07 PM ET by Andy Clifford(Andybuildz)
I didn't ask it to be done Andy! You guys buy "THESE GREATTTTTTTTT DEALS!" remember?????????? Then WE have to live in them while you GUYS take years redoing them to your specifications! Meaning it has to be perfect. Oh and by the way remember you GUYS don't have the time CUZZZZZZZZZZ you are too BUSY working on others homes!!!!!!!!!!!! Yeap I dealt with it!Tamara
Yep I dealt with it!
ut ohhhh.....what does that mean Tamara? EEEEEEE....sorry. Spose you didnt tell all! Sounds like the book I'll be writing about keeping a marriage together during renovations. I think Piff might be helping me with it between his writings for FHB and mildew. MAybe you should write a book with HIS wife cept I'm bettin shes happy. So, c'mon Tamara..whats the real low down. We all love u
Be well
Namaste
OH no!!!!!!!!!! No Lars and I are FINE! Trust me:-) There are days though that I think WHY are we doing this. I tell him as long as it is done before the grandkids start coming. That gives him some time. The oldest is 11 and the youngest just turned 1 in May. Sure didn't mean to sound like I gave him the boot. Tamara
Tamara, maybe all the women here should list their techniques for getting the "honey-do" list jump-started...
Mine involved plugging in the Sawzall and calling down the hallway, "Sweetie, is there anything important inside this old wall?" ;~)
...get an up-north attitude...
What you need to do is swap husbands. You see, on any given weekend most of the guys I know are more likely to do a favor for a buddy and work on his house than to work on their own. Arrange for your contractor-husband to spend weekends working on his contractor-buddy's house, while his contractor-buddy works on your house. Both houses get finished, everybody's happy.
That program has worked for us incredibly well. In 14 years of marriage, we've only lived in three unfinished houses, and that for only about 5,113 days.
Andy Engel, The Former Accidental Moderator
"...What you need to do is swap husbands..." Ummm...errr...Well, I guess the proof of your method lies in your numbers... [VBG]
Architectual Mill working and trim detail. Not the installation part but the creation and approaches.
Handbook of flashing and water. A thorough venture into all aspects of flashing and getting water.moisture away from the residence.
My suggestion is not a book, or a subject, but a request to re-print a poster.
In my local bookstore, that stocks many Taunton books, there is a poster that Taunton had many years ago that is a photograph of the most magnificent tool set EVER.
It is a nice photo, nicely laid out on the poster, suitable for framing and would be the pride of any workshop, I think.
The tools are all so beautifully made, and the case that is holding all of them is so well fitted around each one, it looks not so much like the tools of a master craftsman's lifetime, it looks more like it would have taken the whole lifetime just to build the tools and case!
Please, please, please, Taunton, re-issue that poster just so I can have one for my workshop, so that image can inspire me every day, not just on the days that I can go browse at that book shop!
To help jog your memory about which poster I'm talking:
the wood working (or was it stone masonry?) tools are all fitted with dark, reddish wood grips.
the tool box that they are all shown in is lined (if I remember correctly) in green felt.
the whole set look to be of the same manufacture, or exquisitely well hand made, and seem to be from the late 1800s, I'd say.
I have asked them (the book store) to sell it and they say 'no', I have asked Taunton to re-print it before, and they have said 'maybe'.
So, please make my dream come true, Taunton!
There are lots of titles out there, but what is key for me....if I plunk down money for a book....I want to see that it is written by someone who is extremely knowledgeable in that area, and who probably specialises, not a tourist...."write what you know". A couple of suggestions that were mentioned that caught my eye....like kitchen layout and installation....I'd only be interested if it was written by someone who is doing that every day, every week. Same with architectural millwork (and there is a big gap there....I constantly refer to a couple of classics that are over a hundred years old, and nothing better has come down the pike).....it better be written by a millworker with experience, not someone who tackles a couple of projects a year and figures there's a book project in it. Taunton has a couple of people out there (not Mike G.), who seem to be just churning out book after article after book, and sometimes it's pretty clear they don't have a clue. Unfortunately. It's one of my few gripes with Taunton, but it's there, on the FWW side and on the FH side sometimes.
I figure, for most of us, we might have one maybe two books or a few articles in us max, on the stuff we know best. Eventually, one could become like the Bob Newhart character in the inn, a new DIY book every week, on stuff you've never done.cabinetmaker/college instructor. Cape Breton, N.S
Adrian
Applause applause...You articulated it so well bro. Can you reiterate a bit? Was sorry to see your post end.
One book I love and I'm so sorry to forget the author/craftsmans name is the guy that does those tile books. I learned soooo much from that guy (who happens to be a SYSOP in JLC or whatever ya call that other site. He's right down to every detail. Zero DYSer junk like Time books on how to build a deck with stupid illustrations. Anyway Adrian..you set the scene really well. I want a book on skyhooks and other odd helping devices....
All kidding aside......Adrian is really right on the nail head!
BE well
Namaste'
re - One book I love and I'm so sorry to forget the author/craftsmans name is the guy that does those tile books.
Would that be...."Setting Ceramic Tile" by Michael Byrne ?
I have a copy of that one, along with numerous other Taunton Press books.
Alan
O.K. - Didn't get any response from anyone about a book on building your own trusses. How about if I write one myself called "Spec house building for fun and profit" ???
Or maybe in a year or two, Frenchy can write one on "Timber Framing, the Easy way".George Washington was first in war, first in peace... and the first to have his birthday juggled to make a long weekend.
How about-
Fireplaces- it's hard to find examples of handcrafted fireplaces.
Staircases- the photo gallery here and at the old site are/were the best resources I've found.
Anatomy of a House- diagrams, definitions, etc from foundation to roof. Would have been helpful when I first started researching.
I second the motion for an Urban Kitchen book- and, conversely, Timeless Kitchens, with period details.
Mario Rodriguez(sp?) from over at FWW with taunton just put out a book on fireplace mantles. His work is top notch, and he knows what he is doing. His craftsmanship is top-notch.
add:
Here is the book im refering too. Just out http://www.taunton.com/store/pages/070513.asp
I noticed one on traditional woodwork,from mario. I wish this would be expanded into more Architectual Millwork reference and milling.
Edited 10/17/2002 9:55:09 PM ET by BILL_1010
I need books on
Concrete block/ concrete houses
real stucco for dummies
and Metal building/ garages
concrete foundations be nice too,
re - I need books on Concrete block/ concrete houses
If you are seriously interested in this, you owe yourself to look into autoclaved lightweight concrete block construction, which goes well with stucco exterior finish.
It's a shame this material hasn't caught on in this country.
Thank you very much for those references.
Ah, fireplaces, mantles, and hearths - good for two books, one on antiques (and reproducing) and one on contemporary c/w firebox construction and flue.
Only a short step to decorative chimneys too..
Phill Giles
Unionville, Ontario
Could the sequel be "Divorce the easy way".
Piff,
Divorce the easy way! Home improvements revisited.....Thats pretty funny.....but honestly? It really could make a very interesting book. The do's and don'ts in getting along during a redo. That honestly would be a great book that I think would become volumns. Not so much "spec houses" but rather home improvements in general. Whydga have to broadcast that? Ya couldla written me a private E-MAil. I'd have worked on it with ya...Very cool book.Make it factual and humorous and informative all in one book. Illustrations (my wife was an illustrator (water colors) so that could be done inexpensivly) cartoons and photos....Hmmmmm scratchin' my head now...double hmmmm
Talk soon
Be well and yada yada yada
Right ..Byrne......Sorry Michael......great book!
Be well
NAmaste'
Here's a book I would like Taunton to publish. A book that provides solutions to every possible problem that you could run into during a remodeling project.
Since I'm very busy I would also like it to be a short easy read, say maybe one, two chapters max.
Now I expect royalties after this book is published.
Scott R.
Scott
Problem with a book like that is that there arent enough shelves in a library to keep em..lol.....
And an easy to read two three chapter book????? You a DIYer? Figured
Good luck
Be well
Namaste
Andy 2-3 chapters?? ROFLOLMAOIt's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
I thought about publishing my own book. This book will solve any problem a DIY could face, add value to their home, save money in the long run and will be jam-packed with handed down techniques and years of remodeling experience.
"The Ultimate Guide for Producing Professional Results"
It will be just one page.
Page one… Find a quality Professional and hire him/her!
Scott R.
Wait a minute Scott, I'm a DIYer. Andy Engel, The Former Accidental Moderator
hiya andy, glad to see you're still around. Thought maybe that boot to the upper room mighta cut into your lurking time. Let the thunder crack and the waves roar.
We're going on.
Now I only come here to kibbutz. It's kind of fun.Andy Engel, The Former Accidental Moderator
Tile book by Michael Byrne??? Taunton printed the book but Michael found a home at JLC. He's an interesting character; very opinionated about his craft.
MG
Mike
Thats what I said. I know he's the head of the tile dept there. Most intense people ARE opinionated. One just has to sort of sort through the ego of it all. He sure helped me in his books. Real thoro and precise. I cant imagine a novice could really get a whole lot out of his books but pros like myself sure appreciate that intensity. So I reckon the next book you do Mike ...well, you'll have to decide if its for the pro or DYSer or both. Personally I think coming from FHB youre talking to pros mostly. As you can see from the responses most requests are for the pros. Concrete work, mildew, odd framing designs (thats me.lol) and so on and so forth. One thing I might offer from just a mere serf's point of view is ...put a bit of humor in it. thats where Byrne gets lost IMHO....Seems a bit full of himself which is really ok cause he really knows a lot but.....humor goes a long way. Makes it human. Hmmmmm Humor, Human.......never saw that in print before. Seeeeee?
MAke it fun to read as text books should be for kids. I read a book by this old cabinet maker that I absolutly loved. A German or Swede I think. I'm sure you know his name. Escapes me. HE works out of a school in Northern California. Something...uhhhh School of the Redwoods or something?...I forget. I read his book and called him about ten years ago wanting to be in classes with him. He was actually in his shop when I called at 11 PM. I had a brief discussion with him about what I enjoyed about his book. He spoke in the entire book about attitude of carpentry. Cabinet making. Applies to everything in life. Reckon why I connected so strongly was because I LOVE the ZEN of building. the heart and soul not so much as always the techniques. Far few books on the Zen of building if you ask me. Lots of details but little humor and humankind and heart and soul. Enough on specs and regulations...Hows a bout a book thats a compolation of all that stuff "encased" with what I speak about? Sorry for the rant Mike.
when I was in Jamaica a few years ago I took my rental car through the countryside while my wife played tennis at out resort in Negril. I stopped by a building site. One old white haired JAmaican building with hand tools. A type of framing I never saw before. I pulled next to his site in the middle of a field and walked over to him. He was straddling a sort of crude rafter with a handsaw. He seemed to be happy to see a friendly face. He came down and we shared a Red Stripe six pack (warm). We spoke about building in Jamaica..tools.and me building in the US and tools.....We spent several hours jawin'.... and somewhere I have photos I'll dig out after my move this week and post em if I can find em. I thought......that'd make some awesome book. Carpenters around the world discussing situations and tools of their area....along with the funny times.
Be well and good luck Mike
Namaste'
you talking about James Krenov?
Bill
There ya go. Thanks mate. Fantastic book and incredable man. Wish I had the opportunity to have studied under him but I seem to always be busy using bigger fatter lumber then the furnature stuff. I have done quite a few pieces but I've always got such big projects I cant ever seem to find the time to switch gears from my 30' tape to my folding rule. None the less Krenov's book is worthy of any trade or craft. Do you remember the name of the book I'm talking about? I HIGHLY recommend that everyone here at Breaktime read it! I remember...its THE IMPRACTICAL CABINET MAKER by James Krenov..... a must read for all builders IMHO!
BE well
Namaste'
andy
Edited 10/19/2002 8:44:30 AM ET by Andy Clifford(Andybuildz)
I don't mind the rant Andy. It's funny you bring up your Jamaca experience with the carpenter/builder. I have thought about the book you propose. I think it would be interesting and informative. Though wood framing is not popular worldwide, there are several contries where it still accounts for a decent percentage of homes. I've been to NZ, and Europe an a couple other places and always stop at jobsites. Language barriers aside, most people love showing off their work and I'm always interested in how different things are. I kind of hope that the ICC doesn't sell building codes outside the US because it may McDonaldize the nuances of homebuilding elsewhere.
mike
Mike
As I tried to get across. Its whats in your heart and soul that'd be a great book. Kinda tired of the spec kind of books not that theyre out of line for sure. But....a heart and soul book like the one Krenov did sure hits a person where they keep it with them where ever they go. Krevnov's book sure did for me (The Impractical Cabinet MAker) Kind of like back when ...when I read "The Zen Of Motorcycle Maintenance". Not sure how old you are Mike but if you never read TZOMM then try it out. It still stands the test of time. A book with carpenters or masons or plumbers or whom where ever your heart leads you would sure be a breath of fresh air IMHO and sure would bring you to a place above anywhere youve been so far. Not to mention fun and exciting. No way you could go wrong man but thats just my opinion. Whatta I know. Just a kid from the other side of the tracks. Inarticulate with a temper and creativitity that seems to only get me in troublew mostly..so I pass the buck.....I mean brick..onto you to carry on what you do best. If you need any kind of help just Eme. . Do it brother. Sick of these spec books. How bout just ONE with soul...kinda like Krenov did but for a Taunton kinda crowd.
Be well....really well
Namaste
That's a tall order to fill - soul stuff and all. BTW, I have a first paperback edition of Zen and the Art of Motorcycle Maintenance - thinking that's the book to which you refered.
Mg
Mike,
How bout a book like Zaggats food review for the best deli's for lunch...and the worst
Be well
Namaste
How about a 2000 page compilation of the Best of Breaktime?
-Peter
There are HF types of people - those who understand hexidecimal and those who don't.
Adrian,
I agree that the writer must know what he (she's) writing about. You can smell incompetence even before you finish the first page. I haven't seen too many articles in FHB that are written by amateurs (though most all of us are amateur writers). I have noticed some pretty screwed up work in photos though.
Mike
Ah, yes. I remember that picture, and I wholeheartedly second your motion!
Well stone starts the thought, but Masonry would be a great topic.
Working title: The Essence of Masonry
Foundations and soil.
Materials from poured concrete to Block to brick to natural fieldstone & rock.
Laying technique. facing, level, fill, Mixtures to create mortar, types of mortar.
Tools, tricks, striking, finishing, repointing, Painting, unpainting.
The above synopsis is about 12 to 20 chapters as it would be cut up into a finished product. This has to be a book that is a compendium of information covering the world of masonry.
Certainly not another highschool textbook with simple smattering on lots of topics. Certainly not a shinybook showing only barbecue grills and retaining walls.
Focus on the Homebuilding industry and the methods of construction. DIY types as well. There is a lot of room between the pulp pfaf and the architectural guidebook.
200 pages with a nice compliment of drawings & photo's.
Send me a preliminary copy and I'll proof it for you.
How about a lexicon of construction terms and materials?
It could be real fun to do some regional sections.
It would be a great reference for Breaktimers so they would all know each others lingo.
That's a heck of an idea! Do you guys on the East coast use the term "RCH"?
Brinkmann for president in '04
<<<Do you guys on the East coast use the term "RCH"?>>>
Jimmy
Only in the more expensive neighborhoods.
Be well
Namaste
Andy
Naw the guys on the East Coast are a little less precise. BCH is as close as they measure.
You an engineer? Last time I heard that term was in a Mech Eng class in 1977. It isn't very PC.
I'd be careful, on the Left coast it may be dyed R. It could throw you off by a thousandth or so. Check the roots.
We rock people are very heavy.
How bout a book on all the other books on construction. Like a phone book of all the construction books in print so when we need to refrence we have all the books at hand
Be well
Namaste
Ok, Less effeminate titles
"The Bedrock of Masonry"?
"Heavy Masonry"
"Brick & Mortar"
"Gettin' down to Rock"
"Lyeing about Rock"
Or the Japanese version "Lock & Lye"
Edited 10/29/2002 9:25:28 AM ET by Booch
I hope I didn't give the impression that I object to your title or find it effeminate. I think it's a wonderful title.
The quote is from "The Point," an animated movie made by Harry Nilsson in the early 70's. The Rock People were slow moving, deep thinking folks, kind of like the Ents in the Lord of the Rings. I think that is the essence of masonry: We rock people are very heavy.
I'm impressed you can dig out the title & author. I think I can recollect some of that animation. You must have been a good boy in the 70's.
Mike
A book on cooking options in a kitchen like as in Jenn Air junk...true Dutch ovens next to fireplaces..AGA's.....Fireplaces with spits...smokers......steamers... (leave Jimmy Blodgett outta this one...lol...Mr Brinkman here we come)....So many building devices to cook on and few really are compiled in books towards builders. Just wait till I do my next kitchen. Dutch oven next to the fireplace as its supposed to be with steamer and smoker devices. AGA is fine if yer made of money and have central air in the summer but I havent seen one good book on the subject of cookers in the kitchen.
Be well
Namaste'
Andy
PS....Do we win something if you chose our topic? lol....FHB cap?
Mike, I would like to see a book on remodeling older homes. The book would cover room additions, dormers, conversions of basements and garages to living spaces, improvements to the existing sructure, etc.. It would be helpful to some people to know what to look for in the house also when considering remodeling.
By the way, I found Precision Framing to be an excellent reference and I have used many of your suggestions in practice. (Credit to Rick Arnold also).
Thanks.
I agree with the idea suggested for replacing windows in older brick veneer homes (there's tons in my area). Also I agree with the book on flashing. Every roofing book I've read kind of skims over the subject in passing without really getting into it and how important it is, and not just on roofs. Those are two I would definitely buy.
This is geared more towards decorating than construction...
But how about a book explaining the mysteries behind why people hang pictures of Dogs Playing Poker in their houses?
is that 'tobacco road' I hear playing in the background? Let the thunder crack and the waves roar.
I should think that is obvious, and not deserving of more than a chapter of alternatives. They ran out of Elvis on black velvet, Duh!!! <G>
Dan How about a book of stupid injuries that really happened, to people that should know better. Call it, "I'm not that stupid, am I?"
Mongo...same reason they have plates hung on the wall with the Honeymooners
aIt's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
How about a book "Lifestyle Solutions for Contractors"? Contractors have similar things yanking their chains and have not seen anyone address them. Such as.
Surviving a Cash Flow Crunch
Job Site Nutrition (Avoiding the Big Mac Heart Attack!)
Keep your Back on the right Track (Stretches, Proper lifting, Info about chiropractors and surgery)
Positive Interaction (Assertiveness training for contractors)
Deadline Strategies (How to manage your life, family, etc. when you have a job that requires all of your attention for a period of time)
Fitness for Contractors
The Yo Yo $ (Contractors incomes are volatile to say the least. Sometimes way up sometimes way down...how do you manage it and stay sane?)
There are probably lots of others but I have not seen a book like this.
I look down my nose at people who dare to look down their nose at people.
Mike,
I would like to see a book that shows the different syles of homes and the details that are specific to each.
It seems that each style of home has certain design elements that define it.
Things like cornice returns, and entrance treatments on the outside and moldings and cabinetry styles on the inside.
Mr T
Do not try this at home!
I am a trained professional!
How about a book on building your own trusses...........
Everything goes over your head. You should go to Jamaica and become a limbo dancer.
I think a book on siding and exterior trim could be a great reference book, visually pleasing, and a real good read if you could explain the evolution of various types of siding. With the advent of vinal, fiber cement and composite exteriors, it certainly wouldn't have to be limited to wood, Mike.
Man, oh man, if you had lots and lots of photos and maybe even architectural drawings of various exterior details...maybe categorized by era and architectural style? I think that has real good potential, for professionals and home owners alike.
Window and door treatments? Cornice, soffit and fascia details? Siding and corners? Roof overhangs? Maybe even a thorough discussion on painting, staining? Definately enough there for a book.
Jim,
That sounds like an enclopedia! Would be great. Have you heard of the CD called "Before The Tin Man"? Lots of photos of old (and new) shingle styles and patterns. http://www.decorativeshingles.com
Mike
Hey Mike I've got a real hot seller for you, 'DREAM SHOPS', you go around and photograph the greatest woodworking shops you can find. Take a trip to Europe so you can get some of that old world feel. Break it up into catagories, garages, basements, shops, 900 sq/ft max. Stuff that would make any woodworker drool with envy. Maybe some sidebars about the craftsmen who own them, some of their best projects. I got the idea from the Keith C post in the tavern "how I wasted my Sat afternoon", with pictures 24119.1
sometimes board sometimes knot
Edited 10/19/2002 11:10:08 PM ET by GORDSCO
I'd love to see a book on modern options for homebuilding. This could consist of more modernist design (less is more/stay true to the materials, etc), modern use of materials (steel, concrete, engineered wood, etc.) with some focus on energy efficiency, sustainability, and, building well, but affordably.
Hey Tamara/Cami,
I hold 12 step programs for contractor wives under my table for free I just wanna listen. :)
At Darkworks cut to size made to burn......Putty isnt a option
I vote for a book on siding. Look at the huge number of posts on the subject of weathering of cedar shingles! And yet the issue is never resolved. I'm planning on shingling my house, and I still do not know what to do about avoiding that nasty black color.
Also - Taunton definitely has a bias toward new construction as opposed to remodeling, etc. Lots of homowners and many contractors do the latter. For example, the otherwise excellent book Wiring a House has very detailed instructions on grounding a new system, but is perfunctory on old work issues, e.g. developing a plan for REwiring a house: priorities, etc. So I'd like to get more help with my 1905 house. (I'm not talking about the This Old House Approach -- that's for the rich and their contractors).
Right on Jav- apparently Tauton has yet to discover this niche that needs to be filled. Let the thunder crack and the waves roar.
We're going on.
I got the go ahead from FHB to develop a proposal on a siding book. I do plan on dealing with the remodeling side of the issue as well as new.
You're right there aren't many titles or articles that deal with remodeling aspects specifically. Despite the remodeling market being larger than new construction.
Mg
In part it's probably because it's so much harder to say anything that's universally useful about remodeling. The variety of different ages of existing buildings makes for such a huge range of surprises waiting for the remodeler. Remodeling would be a lot easier if it weren't for this damn house in the way. ;-)
-- J.S.
Drawing on some of the other suggestions in this thread, this would be an excellent opportunity to address the variety of flashing/weatherproofing issues which seem to be lacking in a lot of what's out there on siding right now.
FHB has had some decent articles on siding (the fiber-cement one from a year or so ago comes to mind) however for those of us who don't have much experience in this area, there is very little out there that is comprehensive and contains enough technical information to produce high quality results.
I look forward to the results!!!
This one might have to turn into a set of encyclopedia sized books if you get carried away, but what I have in mind is a " Quality Controls" or maybe " Best Values" to try and compare the main choices of home construction. Sort of a Pros and Cons for each of the major areas, such as types of siding, roofing, and floor coverings. Maintenance versus longevity, what is the best buy. Afterall, most choices involve money somewhere along the line.
Dan
What I would really like is a quality book (and FHB articles) on designing, material selection, and constructing in-home libraries. Not the simple one-wall set of book shelves, but a detailed and in-depth article/book on well thought-out and designed dedicated libraries. Libraries for those who appreciate displaying a quality collection. This would include different ways to shelve and/or display magazine collections like FHB & FWW.
Additionally, I would like to see more attention dedicated to Home Theater design, wiring and construction. And, various other details regarding low voltage applications such as (but not limited to): home audio & video wiring/distribution, home automation, networking, lighting, etc. These are rapidly developing trends that I feel have a definite place in FHB and Taunton publications.
Replacing/updating windows/doors in brick veneer homes.
Ah- Am I to understand you would like to see a book dedicated to replacing/updating windows/doors in brick veneer homes? Let the thunder crack and the waves roar.
We're going on.
re - Am I to understand you would like to see a book dedicated to replacing/updating windows/doors in brick veneer homes?
Rez -
Sorry, I suppose that would be only enough for a couple of chapters.
But it could get quite involved if it covered various types of windows encountered in brick homes/buildings between 1940s and early 1960s and how to go about replacing or retrofitting with modern windows.
Alan
Ya, certainly challenging. Let the thunder crack and the waves roar.
We're going on.
How about a book called "Replacing windows and doors in...." with a chapter on each possible surface you might encounter.
-- J.S.
That sounds like a good approach.
For enough material to fill a book, there needs to be a chapter on interior wall finishes that are encountered and how to go about removing or replacing the old trim and adding jamb extensions (if necessary).
A friend recently replace his windows in a brick house.
He used standard size windows and removed the bricks under the old sill to increase the height to accomodate the standard size.
He then custom poured new concrete sills to accomodate the new windows/opening. Turned out very nice.
He also had to fabricate his own brick mold using alumimum roll stock.
Anyway, there are plenty of details that can be covered but I want it to cover many specifics to brick houses.
Alan
All you have to do is add "replacing the windows in an EIFS building" and you'd fill the book..
Phill Giles
Unionville, Ontario
-"Additionally, I would like to see more attention dedicated to Home Theater design, wiring and construction. And, various other details regarding low voltage applications such as (but not limited to): home audio & video wiring/distribution, home automation, networking, lighting, etc. These are rapidly developing trends that I feel have a definite place in FHB and Taunton publications. "
I agree. Maybe not a book, but an article or two on the construction needs for these systems as they are now a part of every project I do. Not everyone wants a big home theatre, but everyone wants cable, data and phone in every room.
Don
Mike,
After lurking on this forum, and others for about two years your invitation caused me to join.
My standing is as a DIY.
Siding and trim would be a good topic, if it goes beyond wood, vinyl and aluminum. Perhaps expand the subject to residential exteriors thereby including brick, hardiplank stucco, stone (tudor style), and other exterior coverings that do not come to mind at the moment.
I am particularly interested in the cement siding either in an article in FH or as part of a book.
Also interested in steel roofing for residential. Yes I think I know what you are thinking. I read the current posts that indicate steel roof is not a DIY project There are not many projects that I will not tackle. A good explanation of a steel roof may enable me to do the project, or convince me I should not try. When someone tells me this is for 'professionals only', the hair stands on my neck. It just makes me want to do it.
Is there data on noise from thunder storms and hail on steel roofs? What noise reduction systems are used? I have thought of laying Styrofoam (tm) expanded polystryene foam over the roof rafter/truss and below the steel. Will the foam support the steel and a snow load? Can a mansard (barn, hip) style roof be constructed from steel? What adjustments are required? How are valleys flashed with steel? I have wondered how the flashing keeps water from wicking past the flashing between the flashing and the roofsurface steel? Is silicone caulk on the flashing an effective barrier? Is roofing paper placed below the steel? always?
Just a few thoughts for book or article material. Thanks for asking. Enjoy your product, on the web and in print.
anwalt
"Solar Efficient Houses." I'm about to build one, and I could use all the information I could get. However, by the time you publish, my house will, I hope, be finished. But I could really use a good book on making use of free heat.
I'd like to see a book looking at older homes in once-neglected parts of towns that have been restored and renovated into modern, cool houses.
I realize "fine homebuilding" implies new construction, but I'd like to see a book on the stewardship of the fine homebuilding of the past.
How about top ten things you should know before trying to have a house built. Budget, Time management, Money, Delays, Planning problems, Money, Mistakes, Delays, Scheduling problems, and unanswered phone calls. That title may be a little to long, so switch it to " Problems we all try to Avoid" the easy way to build a house.
Dan
How about one on the "Women of Homebuilding" hehehehe We already got some good pics for the book
You forgot getting razzed on Breaktime after you screwed something up.
Building Healthy - "A guide to homes we can live in."
Avoiding "sick house syndrome", outlining material outgassing,
particle emission, etc... and the links to respiratory ailments.
Half the job these days seems to be ridding homes of mildew, mold,
decomposed carpet/padding, etc....
MY health's no better... but the homeowners are better off.
-gwc
Edited 11/3/2002 12:49:31 AM ET by George W. Carpenter
As DIY fool who does know my limits, a serious subject is how to avoid the bubbas in all trades.
If an answer starts with a long and drawn out "Well" or "Yup",
turn around and run.
There should be ways to avoid these folks before one word is exchanged.
Visual clues, etc. besides the BBB and referrals.
Alan
There seem to be books on every facet of residential construction: framing, roofing, siding, foundation and masonry, windows and doors, tile and interior, plumbing & electrical, etc.
What's the one glaring exception? HVAC!
Why no books on designing ductwork, or sizing a furnance of AC compressor? Are these subjects just too arcane to tackle in a book? Can they really be more diffcult thn explaining how to cut the rafters on a hip roof?
Why no books about HVAC ? Think of all the people you know in that trade and try to imagine one even reading a book let alone writing one. .
Phill Giles
Unionville, Ontario
Phill
AMEN
Be well
Namaste
Andy.........PS.Just watch what the next book may be...lol...ughIt's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
I could write a book on DIY housebuilding by yourself
Ch 1 soil engineering/ surveying
ch 2 foundation design/concrete
ch3 masonary
ch4 fighting with box stores
ch 5 trusses
ch 6 steel roof panels
ch 7 plumbing/ rough in
ch 8 framing
ch 9 fighting with crafts/gypsy
ch 10 electrical
ch 11 insulation
ch 12 drywall
ch13 hvac/ government regulations
ch 14 fightin with county inspectors
ch 15 hiring someone to finish drywall
ch 16 painting
ch 17 every screw up possible
ch 18 tools you do not need.
ch 19 misc. floors. doors, and more.
The list goes on and on. it would change the mind of anybody who wants to build a house.
Edited 11/4/2002 9:47:01 PM ET by BROWNBAGG
