In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Brick Pavers on Elevated Slab
| Posted in Construction Techniques on November 14, 2002 01:08am
I am starting to detail a brick paver patio set in a setting bed on a reinforced concrete slab. There will be some living space and open space below it. Water will be drained off the edge of the patio.   If you’ve tackled this in the past, I’m looking for feedback on how you’ve done it, and how it’s held up.
Hisao
  1. Scooter1 | Nov 14, 2002 02:02am | #1
    I might consult the TCA guidelines not for tile, but for general information on how to do this.
    The TCA calls for 4" of gravel for drainage; then a 4" slab. I have seen the slab pitched at the standard 1/4" per foot ratio, although the TCA does not call for this. Then a membrane over the slab, which will help the runoff well, run off. Then a TROBA drainage mat; then the setting bed of 1" of mud; then the finished surface, in your case, brick.
    Any water or moisture will go through the joints, and if it makes it through the setting bed (God forbid) it gets drained by the TROBA, falls onto the membrane and via slope, out the side.
    Regards,
    Boris
    "Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1927
Building a Zero-Energy Home for Less
An Oregon design-build firm makes high performance more affordable.
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
  • Coastal Home That Mimics Nature
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Tool Guide 2022
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
