In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Brick Stains
| Posted in General Discussion on May 26, 2002 06:01am
My house is about 60 years old – Central Calif. Water penetrated the chimney through some cracks that developed in a couple courses of brick. The water traveled down the chimney and came out in the living room, flowing down the front of the fireplace. The living room fireplace brick is now stained with what I’m assuming is lime from the mortar (the stain is white-gray white).
The stain won’t come off by rubbing, scraping or using conventional cleaners and solvents. Any ideas on other things to try? If your answer involves more caustic solutions should I hire someone rather than trying it myself?
Thanks.
  1. Mooney | May 26, 2002 06:16am | #1
    I think I would play with some very thinned down stain.  Take the problem to a paint store, like sherwin williams.
    eagles soar
    Tim Mooney
  2. Piffin | May 26, 2002 04:05pm | #2
    This is eflorescence.
    Fix the leak first so it won't continue.
    Then use muratic acid. This is a very caustic and dangerous product so you may want to hire it done. I saw one guy who had burned a fourth of his face off spilling it undiluted.
    You will need to protect other areas so they don't get bleached out.
    You will want to open the windows fpr ventilation.
    You will where rubber gloves and goggles.
    You will dilute it to about 10 or 20 percent with water. This depends on how stubborn the stain is. Try 10% first.
    Use a scrub brush to scrub it on. Let it set and percolate for about ten minutes, then scrub again and rinse VERY WELL. The left over acid can go in the toilet bowl where it will remove rust stains if you let it set a little before flushing. Just don't set down on it ion the meantime.
    Be sure no little kids have access to the straight acid.
Infill Addition to a Classic Farmhouse
By connecting the home to the detached garage, the architects of this hillside home made space for a home office and guest area.
  • Decompartmentalizing a 1940s San Francisco Home
  • Upgrade Your Window Air Conditioner
  • Podcast 460: PRO TALK With Builder Keith Bohling
  • How to Frame an I-Joist Roof
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
