Is the Bruce 3/4″ solid wood, prefinished, any good?
Whenever you are asked if you can do a job, tell’em “Certainly, I can!” Then get busy and find out how to do it. T. Roosevelt
An FHB Podcast listener wonders if they can fix a failing foundation with PWF, the crew weighs in.
the higher end stuff is find the cheaper stuff has relatively sharp "stocking feet catchers" on the square edge cuts often not cut square, requires cosmetic filling lot of curvature to the stock, more waste finish has dust or imperfections that look like it
higher cost goods are better machined or micro bevel edged on the butts straighter pieces too just installed their 5" oak plank prefinish made in china, beautiful stock straight, well milled and coated white oak, looked like old growth stock w tight grain waste factor below average
Ed2,
Not sure what you are saying. It's a staple down product. No filling required.
I've used it (5/16" "Nat Reflections") IMO Not a bad product for the money. Not great either. @ $4.15 sq/ft it beats Pergo like products.
WSJ
edhilton was asking about bruce 3/4" prefinished solid wood flooring, takes 2" staples w 1/2" crowns or 2" nails at 5/16", is the nat reflec. staple down you're talking about an engineered which takes the 3/8" crown staples? don't think i've ever seen an out of square cut on engineered goods, regardless of brand
the less expensive bruce solid wood flooring i've installed is imo not milled that well lot of butt ends which aren't square, leave little pie-slice openings which need filler if you don't catch them before fastening find it most often on shorter pieces, maybe production snipe problem
the cheaper lines have micro bevel on the long seams, but not on the butts which are called "square cut ends" those cuts often seem sharp in comparison to other brands i can usually find something w better milling in same price bracket and substitute it for bruce the better the goods you start with, the better the job looks when completed
has worked fine for me.
not sure I've ever seen any prefinished w/o a micro-bevel?
Buck Construction, llc Pittsburgh,PA
Artistry in Carpentry
Here is a photo of Bruce 3/4" solid (Fulton LG Strip) prefinished that I just laying. I had no problems. 2 sticks out of 200 sq ft had non-square ends, a few boards were warped beyond belief, and oddly one box was full-o-shorts. Other than than, all the other boxes had fairly long pieces (1' to 6', most 3-4'). It was fairly comparable to unfinished hard wood. The finish is great. There is a little irregularity between boards, but it makes it look like a real wood floor, not a pergo floor. The edges are not beveled, but more like crowned and eased, so there isn't a groove to catch dirt.
Andrew
Curious , you say one box was full of shorts, the rest were full of longs 1-4'
1) just how short was the shorts, less then a foot, yikes
2) you consider longs something over 1 foot, yikes
Ive often thought of trying the prefinished Bruce and Lumber Liqiudators but not if the lengths are only 5 inches
where Im located I havent seen anything in real wood less then 2 feet and I sure as heck wouldnt waste my time installing anything smaller unless it was a piece of trim or finish out a run or near a vent, even then I would think hard if I wanted to and what my customer might say
