The cabinet maker I chose is asking whether I want MDF verneer or multi-ply verneer slab doors. I ask what’s the difference, he said MDF doesn’t warp. What would you recommend?
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
How will the edges be finished?
In both cases it will be verneer (tape) edging.
I have made many doors from mdf they are all holding up very well , wet areas,( bathroom under kitchen sink etc..) mdf doors I use extera great product ,
MDF for Cab Doors
Thanks,
I guess the benefit of being warp resistant would balance my other concern with MDF which is it's ability to hold screws. Have you guys had any difficulty with that?
Screw holding is less of a problem with the right screws
MDF hold screws pretty well if you use the correct screws, and remember not to screw them in too close to edges.
When you get hinges
Get them with the plastic inserts for the screws. Hold well, removing hinges no problem. This for cup hinges.
MDF for Cab Doors
Good idea!
