Cabs fastened to ICF walls
Gene_Davis | Posted in Construction Techniques on August 18, 2006 02:29am
How does this go?  We’ve got two kitchens to do in which some base and uppers are against walls done with Logix ICFs.
I can see, because the walls aren’t rocked yet, that the blocks have embedded plastic “nailer” strips running vertically on 8″ centers, but how much screw purchase do these offer for mounting cabs?
Does anybody go to the trouble of hogging out the block and inserting 5/4 softwood blocking?
  1. JonE | Aug 18, 2006 03:06pm | #1
    I've got Reward block, and I asked myself the same question.  The nailers are 1-1/2" wide on 6" centers in Reward.  So I experimented.
    Bottom line is, if you have drywall on the wall and manage to hit three or four of the nailers with a coarse thread screw, the cabinet will break before it falls off the wall.  I tried removing a few snapped deck screws from my blocks after removing bracing, and I could not just pull them out without totally wrecking the block.  I has to snap a Vise-Grip on each one and twist them out of the hole.
    No need to put in blocking.
    CapnMac | Aug 18, 2006 04:30pm | #2
    What is the finish surface supposed to be?  If it's 1/2" wallboard, you can install 1/2" ply by screwing it to the nailer strips in the ICF to make a cabinet nailer.  The plywood will be nice and rigid.
    Heck | Aug 18, 2006 04:38pm | #3
    Sounds like AARX or 'Blue Block' ICF's.
    They have a plastic stretcher every 8", and if you hit these, it will hold cabinets.
    However, these srips are not continous vertically. There is a small gap in plastic where the ICFs are stacked on each other. If you happen to hit this space, no plastic.
    If you want hit something substantial, there is concrete 2.5" into the foam. Use the appropriate screw.
    "Citius, Altius, Fortius"
  4. Brian | Aug 18, 2006 04:45pm | #4
    Gene - We thought of putting sheet metal behind the drywall, or plywood where the cabinets would be.  In the end we screwed the boxes to the soffit above, and then found the "studs" behind the foam and screwed to those.
    I spent more time thinking about it than necessary - as it turned out, the studs were quite strong, and if you use enough screws your cabinets will be very secure.
    Treat every person you meet like you will know them the rest of your life - you just might!
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
