Cellulose blown into walls
CaseyR | Posted in Construction Techniques on February 24, 2007 05:03am
The contractor just finished blowing cellulose into the walls of my 1130 sq ft 1957 ranch with stucco exterior walls. They started with three guys but about an hour into the job, one left. They used what looked like a sharpened piece of 3/4″ EMT conduit to punch a hole in each stud bay and then blew in the cellulose with a nozzle that looked like a pipe nipple attached to a globe valve. They also carried an on/off switch to control the blower that was left in the truck. Before blowing, they probed the holes to make sure there weren’t hidden fire blocks in the walls (my house has quite a few). After blowing the cellulose, they poked a cork in each hole and covered it over with drywall patch. Less than 4 hours later, they were finished and gone. For the $1280 they charged, there was no way I would have wanted to do it myself. This is the S.F. Bay Area and everything associated with remodeling seems astronomically expensive. I would consider this a true bargain compared to what I have had to spend on painting, window installation, etc. This was done from the inside and the house was pretty much empty, which may have speeded up the process, but they said they charged about the same to do the job from the outside, even with stucco walls. I think the holes in the drywall can be covered up pretty completely, I am not sure that would be the case with patching the stucco from what I have seen, however.
  1. Dave45 | Feb 24, 2007 06:09am | #1
    Patching stucco isn't all that difficult and may be preferable if you're planning on exterior painting in the near future.
  2. curley | Feb 24, 2007 06:48am | #2
    If your wondering if they did a good job you should of counted the bales of cellulose they used . In dense packing, I believe 3 lb cu ft. If you can figure the volume of the walls, the bales are 22 lbs each
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
