FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Ceramic Tile
| Posted in General Discussion on October 14, 2001 01:38am
I am doing some work in an old appartment complex turned condo unit.The bathroom floor had the original mozaic ceramic tile.There were some loose tile around the raiator so after I removed the radiator, I then removed the loose tile and loose mortar in that area.The area of loose tile was about 8″x6″.I found the loose mortar to be about 2 1/2″ deep with more solid concrete below that.I also noticed that part of the floor was warm so I’m assuming that the pipe that feeds the radiator also runs through this mortar.
Is anyone familiar with this type of tile installation that was done years ago and how I might handle this? Can I patch the loose area with some sort of vynal cement product or floor leveler and then put down the new ceramic tile over the old?
I appreciate any help.
  1. IMOnDEdge | Oct 14, 2001 01:38pm | #1
    I am doing some work in an old appartment complex turned condo unit.The bathroom floor had the original mozaic ceramic tile.There were some loose tile around the raiator so after I removed the radiator, I then removed the loose tile and loose mortar in that area.The area of loose tile was about 8"x6".I found the loose mortar to be about 2 1/2" deep with more solid concrete below that.I also noticed that part of the floor was warm so I'm assuming that the pipe that feeds the radiator also runs through this mortar.
Managing HVAC Load Calculations
It is imperative for someone at the end of an HVAC installation to commission the job to ensure the efficiency of the system.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • Code Check Complete 3rd Edition
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
