Hi Guys,
I’m trying to decide which laser level to buy. I’d like to get one that is accurate enough to do foundations/large layouts, but also small interior jobs as well. I’m a pretty small scale remodeler right now, but hopefully doing some larger scare projects soon, so I’d rather invest $1000 now and have a long lasting tool rather than spend $500 now just to have to spend another $1000 sometime in the future. I have been checking out the specs on David White, CST/Berger/Lasermark, and they seem like what I am looking for, but wanted to check and see what other guys were using and suggestions/tips, etc?
Thanks!
Edited 10/1/2006 5:36 pm by KidBuilder
It's hard to go wrong with David White stuff. It all seems to be good.
Remember that you can't really see the laser outside most of the time (unless it's dark) , so you will need a detector.
My little old Robo Laser is the only one I have that I can see in the sunlight.
I like to be able to turn the level off and on remotely. That is a very handy feature, however most levels don't have that available for some reason.
I excavate a lot of sewer lines so I like a level with a grade feature.
Some people find a need for a level that will project vertical lines
I worked with another guy this summer who had a Porter Cable laser level which did vertical, both above and below the level. It also had a sort of autolock, when it was level (or plumb) it would lock in, rather than waiting for the inner level to stop swinging. I plan on getting a laser level sometime soon and that's the one I'll be looking for, or something similar. One thing for sure, since I do a lot of handyman stuff I definately want one with the above and below plumb line.--------------------------------------------------------
For a good time, visit MyToolbox.net See some of my work at TedsCarpentry.com
Check out what PLS has to offer. The company is good (in my dealings with them-human beings that know what it's like to be in the trades). I have the PLS 2 but the PLS2E KIT is for both in/out. They have several others which may fit your needs better, do some study.
PLS2E SYSTEMView Image
PLS2E SYSTEMINDOOR-OUTDOOR LAYOUT IN THE PALM OF YOUR HAND.The PLS2E can be used outdoors with our exclusive PLS LD detector. See our New Products Page for details on the PLS2E System.
THE PLS2E SYSTEM INCLUDES:• PLS2E Laser Unit• Wall Bracket• PLS LD Detector• PLS2E Pouch• Carrying Case• Operating Manual• 1 Year Warranty
My PLS2 has lasted professional use very well in the over 3 yrs of operation.A great place for Information, Comraderie, and a sucker punch.
Quittin' Time
Calvin got me set up with the PLS2E.
I cannot say enough good things about it. The detector makes outside use a breeze.
Up till I got this laser, I dealt with a David White transit. It is an excellent tool, but having a laser level is so much easier to work solo. I've made so much use of it for indoor work that I wonder how I did without so long.
Check out the PLS line, you won't be sorry.
Terry
Another vote for the PLS2E. Just got mine a couple weeks ago, but it has already proved itself. Nice bright line inside & works great outside with the detector.
Mike
To work from rough site to finish, consider a pair of laser tools from PLS.
The PLS5xx with detector will get you from dirt all the way through structure top-out.
Inside, the PLS2e will handle all your window and door setting, and trim-out needs. You don't need the detector version of this one.
Now, what will you do with your change from the large?
http://www.amazon.com/Pacific-Laser-Systems-PLS2E-KIT/dp/B0006TJ5QK/sr=8-2/qid=1159753573/ref=pd_bbs_2/102-2421446-3698533?ie=UTF8&s=hi
I don't see how to save $$ by buying 2 lasers.
They are two different animals. The 5 is a dot generator, with greater long-shot accuracy than the line-generating 2.
We have both and I know. The 5 will give you perfect right angles for foundations, framing, and such. It will plumb you way up there.
The 2 gives you a plumb and or level line on a surface. Turn off its plumb function to fix the two-way line and you can rotate the "X" to do stair work or begin tile and flooring layouts.
Thanks. That clears it up.
PLS 2 and 5. 5 is great for framing, 2 for finish work.
