Help!! I am installing a 24″ circular window from Anderson. The manufacterer does not sell an exterior trim kit for the unit. Is sliced J channel the only way to trim the outside? The house has aluminum shake siding.
Pat: I used to make circular window trim for a place I worked for, if you are interested I can refer you to them.
rjt, thanks for your input.Please send any info you have concerning your former employer to [email protected]
Pat,there is a flexable J channel available. It's made for just what you're doing.Vince
*Yes there is a rubber j-channel that would work fine. it usually comes in only white but I believe it can be dyed or stained if need be. It usually sells for about 10 bucks per stick and is 12 ft +/- long.You can also be real crafty and make an exterior wood trim piece yourself. if it is round, that would be a cinch.Pete Draganic
Help!! I am installing a 24" circular window from Anderson. The manufacterer does not sell an exterior trim kit for the unit. Is sliced J channel the only way to trim the outside? The house has aluminum shake siding.
