Clapboard repair vs replace?
ken7 | Posted in General Discussion on August 18, 2006 07:08am
Folks – As part of the prep work for repainting the cedar clapboard exterior of my house, I’m working on fixing the cedar claps where they have deteriorated on the southern exposure side of the home.
I’m finding it difficult to replace one or two claps at a time because in removing them it’s very easy to break the ones above and below, so the area being repaired gets bigger and bigger.
I’m wondering whether I can just repair the claps which are only cracked a bit by filling the cracks with caulk. There are also some claps which are intact, but warped so that the bottom edge is pulled out away from the house. I was going to replace these, but I’m wondering if a line of caulk underneath them to prevent rain getting blown up there will do?
I know it’s suboptimal, but surely I can’t be the first to wonder if I really need to rip off half the side of the house.  Anyone care to share their clap repair experiences? Many thanks –
Ken in North Granby, CT
  1. YesMaam27577 | Aug 18, 2006 09:19pm | #1
    you need two tools, maybe you already have them......
    A reciprocating saw with a metal cutting blade. Reach up behind the bottom of the claps to cut off the nails with visible heads. This loosens the bottom edge of the board.
    And a shingle ripper -- one that's been sharpened. Use it to find and cut the blind nails. Then voila, the clap falls on the ground.
    Or, yes, you could use caulk. But not the cheap stuff. use a paintable siliconized caulk. But you won't be as happy with the result, no matter how hard you try.
    Unless you're the lead dog, the view just never changes.
      IMERC | Aug 18, 2006 09:37pm | #2
      slit the laps with yur razor knief brfore you do much of anything...
    2. ken7 | Aug 20, 2006 04:54am | #7
      Thanks - I'll see if I can find one of those shingle rippers - think I saw one at the big box.
      I had already tried my recip saw on the nails. Between the awkward angle and the saw grabbing and lurching into the wall I was still breaking the claps. However, I tried a hacksaw blade just held in my hands and that cut the nail fairly well. A bit more work, but I may cobble up a handle which should help.
      Ken
  2. DanH | Aug 18, 2006 09:46pm | #3
    I suppose it goes without saying that the replacement siding should be back-primed. Will go a long way towards preventing curling.
    Or if you can find some old (reclaimed) cypress siding that matches the profile, that stuff is much more stable and resistant to warping/splitting. (It is a lot softer, though.) I think it was used on a lot of homes (at least as far north as Kentucky) prior to WWII.
  3. JohnSprung | Aug 18, 2006 10:27pm | #4
    > .... I'm wondering if a line of caulk underneath them to prevent rain getting blown up there will do?
    What I've heard about it is that claps shouldn't be caulked, they're supposed to breathe.  It's like stucco, the water stops at the tar paper or whatever that's behind the decorative material.  Water getting in isn't a problem so long as it has a way to get out again.  That's the theory behind the design.  Claps or stucco only serve to keep the sun and wind off the moisture barrier.
    If that explanation is in fact correct, then the crucial issue is to not eff up the moisture barrier while doing this work.  Likely others who know better than I will comment here.
    -- J.S.
    hammer1 | Aug 18, 2006 10:32pm | #5
    Most clapboards are made by resawing a 1x6 board diagonally. This often will cause the clapboards to belly, either curling up or bowing out. You can't re-nail these or they will split. If they were installed with nails every eight inches, the nails would have helped to hold the clapboard from moving so much.
    Repairing and replacing clapboards isn't a job for the impatient or those with ham fists. You have to take your time and be methodical or you will end up replacing the whole wall. In some cases, that's not a bad idea. If your siding is split and curled, it isn't doing it's job in helping to keep out air and weather. Caulking is a temporary fix since the clapboards will continue to move and break those joints. All the hard work you put into painting will be shorter lived. You will have paint flash problems trying to cover a smeared on mess of caulking. If you don't fix things correctly this time, you will have to do it eventually. Too bad, good clapboard jobs can last 200 years, poor ones barely make it 10.
    1. ken7 | Aug 20, 2006 04:56am | #8
      Hammer, thanks. I guess the "do it now or redo it later" was kind of what I thought might be the case, but I'm glad to actually hear it. At least now I won't wonder if I'm wasting my time and $$$.
      Ken
  5. ANDYSZ2 | Aug 19, 2006 05:13am | #6
    I like to run my saw right below the good board above the bad one ,set the depth so you cut thru about 95% of the bad board then pry out and snap free the bad board.Then pry up on the good board and pull out your left over rip.
    Then when I put the new board back I may cut it down so that it bumps up to the old nails if it is required but I usually have pretty good luck  getting the nails out.
    ANDYSZ2
    WHY DO I HAVE TO EXPLAIN TO FRIENDS AND FAMILY THAT BEING A SOLE PROPRIETOR IS A REAL JOB?
    REMODELER/PUNCHOUT SPECIALIST
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
