Clawfoot tub in 2nd story bath!!
wavy | Posted in Construction Techniques on November 16, 2006 05:10am
I want to replace a marble surround and jetted tub with a cast iron clawfoot tub in my 2nd story bath. The span is 122″ with 2x10s (looks like fir?) on 16″ centers. Subfloor is 1 1/8″ 4×8 plywood.
I’ve done some carpentry before and know how to read the joist load tables. I don’t see any problem. But since I’m not a pro I’m thinking I may have overlooked something. The tub I’m thinking of is 254 Lbs and 60″ long and would be perpendicular to the joist direction.
Any ideas or suggestions would be appreciated!
  1. RedfordHenry | Nov 16, 2006 05:55am | #1
    That tub, full of water (~350 lbs), plus a bather (assume 175 lbs) totals less than 800 lbs.  Probably not much more than the marble and existing tub that you are removing.  I say you're good.  Getting the tub up the stairs will be the fun part.
      JDRHI | Nov 16, 2006 06:08am | #3
      LOL....that's what I envisioned this thread being about!
      Hey wavy...sounds like yer good to go!
      FREE SPONGE BOB,SANCHO PANTS!
      1. wavy | Nov 16, 2006 04:48pm | #4
        Thank you all for taking the time to reply. For the really fun part of dragging the tub up the stairs, we're thinking of wrapping it in a huge blanket and sliding it up the carpeted stairs. I've 3 strong young helpers. If that doesn't work, we'll try something else."No hill for a stepper!" as my dear old dad used to say.Thanks, again-wavy
  2. philarenewal | Nov 16, 2006 06:08am | #2
    I agree with RedfordHenry.
    2x10 16" oc for basically a 10' span, covered by 1 1/8" of ply is a good floor.  A very good floor.
    To noodle this a little, 2x10 on 16" centers at 15' span covered by 3/4" ply is "rated" for 50#/ft. sq. (by my local code at least).  Assuming the tub is 5' long by 2' wide = 10 ft. sq. = max distributed load of 500# on that floor area.  You say your tub is 254# on that framing and subfloor.  Should be no trouble at all.
    In more of a reality, your 1 1/8" subfloor will do a good job of distributing that load, plus the tub is likely wider than 2', plus your span is a good deal shorter than the design max for a 2x10, plus the remainder of the floor is unlikely to ever see anywhere near its total design load so I'd think you are more than good to go.
    "Let's get crack-a-lackin"  --- Adam Carolla
PVC for a Rot-Proof Fence
Built with rot-proof material with traditional tools and techniques, this classic border is engineered to never sag.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
