clean and paint laminate
bigbossman | Posted in General Discussion on May 20, 2007 10:43am
What would be the proper stuff to use to clean and paint an laminate bath vanity? Is there some product that would help make sure that paint will adhere to the caninet since it is in good shape but the color has to change.
  1. user-196900 | May 21, 2007 01:36am | #1
    Try your local bathtub refinisher
    BarryE | May 21, 2007 03:34am | #2
    My first choice, for long term, would be not to paint the cabinet or recover it with another laminate.
    If that doesn't work The best plan of action would be to give it a good cleaning, sand it to give it some tooth, use a good bonding primer like XIM, and topcoat it with a good quality waterborne like SW's ProClassic or BM's Impervo
    Barry E-Remodeler
  3. eleft | May 21, 2007 03:59am | #3
    My '69 Bertram had faded laminate bulk heads, I cleaned with acetone scuffed with a scotch medium pad and painted with urethane paint 2 years ago and it still holding up.
    al
    1. bigbossman | May 21, 2007 04:05am | #4
      Do you guys think that a quart of paint of paint would cover a 30x19 cabinet base if using XIM bonding primer and some SW?
      1. calvin | May 21, 2007 04:43am | #5
        All sides, top bottom and underneath.A great place for Information, Comraderie, and a sucker punch.
        http://www.quittintime.com/
  4. DonCanDo | May 21, 2007 05:08am | #6
    Before you paint the vanity, I suggest you try whatever technique you've chosen on a piece of scrap.  I'm suggesting this because I've experimented with painting laminates and while I have had some success (scuffing and Zinsser BIN worked the best), I do not have enough confidence in it that I would actually paint a laminate surface for a customer.  Well, actually I might... but only of it were a surface that were never touched by anything/anybody.
    MarkH | May 21, 2007 05:42am | #7
    You can use a automotive type epoxy primer over sanded and degreased laminate.  It's nasty to work with, expensive, and will ruin your gun if not properly cleaned immediately after use, but it's hard and sticks good.
Episode 1: Drywall Tools for the First Coat
Learn about mechanical and automatic tools such as the taper, the compound tube, and the banjo to make your drywall job better and easier.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
