cobbling a vapor barrier
terryb | Posted in Energy, Heating & Insulation on July 24, 2006 07:31am
Last winter I removed the insulation (6″ x 24″ batts) from the garage ceiling when the roof leaked. Roof’s fixed and I’d like to put the insulation back up. The roof is just plywood on 2×6 rafters – no sheetrock. The insulation has been up and down so many times to put in wiring & stuff that the vapor barrier face is all chewed up. Just as soon not have to buy new insulation. What could I staple up under the insulation to give me a decent vapor barrier – at least ’til I pull it all down for the next swell project?
Thanks in advance
  1. rez | Aug 07, 2006 07:26pm | #1
    Greetings terry,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    "The old Quaker Meeting house is almost 300 years old and as my sawzall made its way into the pegged ancient wood, a smell emerged that told me about dried, cracked things. The ancient Quakers sitting in the well worn pocket of their silence on the darkened pine benches were whispering something to me across the years.  Something about why I was here, why we're here.  Lord but it was hot. I reached in to clear anything out of what was the sill, nothing but the hardened mud, lime and sand mortar, dust and shadows."  -- Jer
      IMERC | Aug 07, 2006 07:27pm | #2
      rez must be back full time...
      be and bored..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
      IMERC | Aug 07, 2006 07:29pm | #4
      and chicken wire over that...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
      1. rez | Aug 07, 2006 07:38pm | #6
        or some half inch foilbacked celotex put up with a few screws and plastic washers.
        be prepping for a return engagement"The old Quaker Meeting house is almost 300 years old and as my sawzall made its way into the pegged ancient wood, a smell emerged that told me about dried, cracked things. The ancient Quakers sitting in the well worn pocket of their silence on the darkened pine benches were whispering something to me across the years.  Something about why I was here, why we're here.  Lord but it was hot. I reached in to clear anything out of what was the sill, nothing but the hardened mud, lime and sand mortar, dust and shadows."  -- Jer
          IMERC | Aug 07, 2006 07:40pm | #7
          or that 1/8" insul board..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
          1. rez | Aug 07, 2006 07:45pm | #8
            could duct tape the edges of fanfold siding up there.
            be frugal"The old Quaker Meeting house is almost 300 years old and as my sawzall made its way into the pegged ancient wood, a smell emerged that told me about dried, cracked things. The ancient Quakers sitting in the well worn pocket of their silence on the darkened pine benches were whispering something to me across the years.  Something about why I was here, why we're here.  Lord but it was hot. I reached in to clear anything out of what was the sill, nothing but the hardened mud, lime and sand mortar, dust and shadows."  -- Jer
            IMERC | Aug 07, 2006 07:59pm | #9
            possible...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
          3. rez | Aug 07, 2006 08:02pm | #10
            just don't tell that P.I.T.A.P.I.B.I. mooney about it or there might be trouble in the wings."The old Quaker Meeting house is almost 300 years old and as my sawzall made its way into the pegged ancient wood, a smell emerged that told me about dried, cracked things. The ancient Quakers sitting in the well worn pocket of their silence on the darkened pine benches were whispering something to me across the years.  Something about why I was here, why we're here.  Lord but it was hot. I reached in to clear anything out of what was the sill, nothing but the hardened mud, lime and sand mortar, dust and shadows."  -- Jer
            IMERC | Aug 07, 2006 08:10pm | #11
            okay..Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
    IMERC | Aug 07, 2006 07:29pm | #3
    8 mil plastic..
    WOW!!! What a Ride!
  3. piko | Aug 07, 2006 07:36pm | #5
    Firstly - the garage is not a habitable room, so does it need a VB? If you think so, then temporarily use a cheap medium poly plastic (milroll, eg) until such times as you put the finish with the code-approved VB. If you don't think it needs a VB, then just staple string on the underside of the joists until ...etc.
    All the best...
    To those who know - this may be obvious. To those who don't - I hope I've helped.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
