In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Combining circuits
sharcitect | Posted in Construction Techniques on August 25, 2009 05:40am
Hi all-
I hope you can help me. I have an existing 3-way light switch (with 1 light on the circuit) ganged with a 2-way. I want to remove the 2-way and add the 2 lights on that circuit to be switched from the existing 3-way. I don’t mind leaving a non-working 2-way switch in the wall or getting a blank plate to cover it.
What should I do with the white and black wires on the 2-way to get this to work?
Thanks in advance
    SamT | Aug 25, 2009 06:35pm | #1
    Not enough info. 2-way and 3-way are common names for the same thing.
    Count the number of screw connectors on the switches, but not the ground terminal, and let us know waht you have.
    SamT
    A Pragmatic Classical Liberal, aka Libertarian.
    I'm always right!
    Except when I'm not.
    1. sharcitect | Aug 25, 2009 06:41pm | #2
      Thanks Sam.I meant 2 wire and 3 wire + ground.
      The 3-way switch has 3 screws + ground
      The 2-way Switch has 2 screws + ground
        SamT | Aug 25, 2009 07:43pm | #3
        Probably:
        you have the common switch, 2 terminal/g, feeding power to the 3-way.
        Probably:
        the 3-way only has two wires +g attached to it.
        Probably:
        Both switches have to be in one particular combination to turn the light on.
        Probably:
        You can connect the hot, black wire on the common switch to the "Traveler", (the wire that runs between the two switches,) then replace the 3-way switch with the common switch, and put a blank cover on the unused switch box.
        Please, before you do anything, if my "probable" assumptions are wrong, get back to us.SamTA Pragmatic Classical Liberal, aka Libertarian.
        I'm always right! Except when I'm not.
    BillHartmann | Aug 25, 2009 08:03pm | #4
    A 3-way "system" has at least one other 3-way switch and possibly one or more 4-ways in between then.
    Even for a simple 2 switch 3-way circuit there are about 4 or 5 different ways that it can be wired. None of them allow a light (or another light) to be connected at either 3-way switch. And some of them don't allow a light to be connected at either end.
    To determine what you have you have to list each cable that connects to the switch. Which color in which cable connects to which terminal on the switch. Ignore any grounds (green terminal and bare or green wire). On the switch you will have 2 terminals of the same color, those are the travelers, and 1 of a different color. That is the common terminal.
    And any wires in those cables that connect to each other.
    And do that at both 3-way switches.
    1. sharcitect | Aug 25, 2009 08:11pm | #5
      Thanks. When I get a chance I'll turn off the power and look at / note the wires and re-post.
        SamT | Aug 25, 2009 08:18pm | #7
        If you actually have three wires connected to the 3-way, you may have an unkown 3-way somewhere.SamTA Pragmatic Classical Liberal, aka Libertarian.
        1. sharcitect | Aug 25, 2009 08:31pm | #8
          I will definitely count / note all wires and re-post.I think I may have not been too clear on the original post.I have a three way circuit: 1 switch at the top of the stairs, 1 switch at the bottom of the stairs that both control a single light. Next to the switch at the bottom of the stairs (in the same gang of switches) I have a separate switch that controls 2 additional lights downstairs. I would like to combine these 2 additional lights onto the existing 3-way circuit and either eliminate or leave inoperable the 2-way switch. When I get a chance I will note all the connections in the 2-way and 3-way circuit.Thanks
            SamT | Aug 25, 2009 08:39pm | #9
            Do you want one, and only one, switch to control all those lights?SamTA Pragmatic Classical Liberal, aka Libertarian.
          2. sharcitect | Aug 25, 2009 08:46pm | #12
            Sam-I would like to have all 3 lights on the 3-way circuit so I can switch them from either upstairs or downstairs. Thanks
          3. sharcitect | Aug 25, 2009 08:47pm | #13
            And sorry for all the confusion too
            SamT | Aug 25, 2009 08:58pm | #14
            Sharcitect,
            You must ignore all my suggestions above. See Bill's #11 post to me.
            I think that you have now correctly identified your switches and circuits.
            The only problem I can now foresee is that you might have power to the 3-way circuit coming in at the gang box  at the bottom of the stairs and the power going to the  light coming from the 3-way switch at the top.
            If you're really lucky, the power comes in at the top and the light connects at the bottom or you have a 3 wire +g running from top to light to bottom. Otherwise, you'll have to get another wire from top to bottom.SamTA Pragmatic Classical Liberal, aka Libertarian.
            BillHartmann | Aug 25, 2009 10:45pm | #15
            Or you might have a single connection at one end with a switch leg from the light..
      SamT | Aug 25, 2009 08:16pm | #6
      He has one switch with two terminals and one with three terminals. Ignoring ground.SamTA Pragmatic Classical Liberal, aka Libertarian.
        BillHartmann | Aug 25, 2009 08:40pm | #10
        But unless he has a 3-way that is just used as a SPST switch he has a 2nd 3-way someplace.And as he has since confirmed..
          SamT | Aug 25, 2009 08:43pm | #11
          Bah! I miss one word in the original post and it derails my whole train.
          "Ganged"SamTA Pragmatic Classical Liberal, aka Libertarian.
Reusable Flood Bags for Fast Bulk-Water Control
These bags from Quick Dam arrive compact and swell to form a protective barrier on contact with water.
  • Podcast 487: Cedar Closets, Conditioning a Woodshop, and Regional Construction Jargon
  • Podcast 487: Members-only Aftershow
  • Festool's Domino: Worth the Dough?
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
