Composite decking advice
SVH | Posted in Construction Techniques on June 23, 2008 04:53am
I have a client that wants his old deck rebuild using composite decking.  I have built my fair share of decks just never with a composite deck material.  Since there are a ton of companies selling one form or another of decking I just wanted to see what you guys and gals (politically correct) were using.
The deck is going to be build in southern <!—-><!—-> <!—->Virginia<!—-> <!—->.  It will sit in the sun from sun up till sun down.  We haven’t discussed size or any of the details.  I want to be able to go in and suggest the best product.
  1. kltzycrpntr | Jun 23, 2008 05:06am | #1
    I'd stay away from composite. Look into PVC, such as Azek (formally Procell) or Trex makes a PVC as well as Timber Tech.
  2. peteshlagor | Jun 23, 2008 05:21am | #2
    I've got a composite deck I'm looking to replace with a more modern variety.
    The latest Consumer Reports has an article on decking, both types and stains.  They're somewhat happy with composites, but find the plastic pvc stuff has too much sagging to recommend.
    The composite I want to switch out has cracked and broken away from some nails, it sags, and is impossible to use in the hot summer sum of Denver.  One cannot walk on it in bare feet, it is soooo hot.
    So's I'm looking for ideas too.  A light color with a bit of texture, that doesn't sag.
    1. kltzycrpntr | Jun 23, 2008 12:53pm | #3
      Because composite decking gets so hot, that's one of the reason's I like PVC. You can screw it close to the edges and it won't crack like composite. As far as the sagging, I framed my deck 12"o.c. If you picture frame a deck and 45 the corners, PVC will open up on the joints, but not as bad as composite. Same holds true for butt joints. PVC is so much lighter and easier to work with IMO. I've taken several scrap pieces of composite and PVC and put them out in the sun to see how they compare. Depending on the color, there is a slight variation on how hot they get. But PVC takes on very little heat from the sun. I have installed several PVC decks and the homeowners are extremely happy with it and thank me for introducing the product to them. As they thought 'Trex' was their only option.
  3. Pelipeth | Jun 23, 2008 01:15pm | #4
    I just went thru this drill with my own home, decided to go with IPE (all of 2mos. now) . So far we love it, feels like an interior finished floor under foot 3/4x6. I also like the silver/gray patina it turns to. Approx. same $$$$$ as the PVC and composits.
  4. SVH | Jun 24, 2008 03:15am | #5
    Thanks for the info.  I'm going out on Thursday night to take a look at the job and now I have a few ideas.
    Edited 6/23/2008 8:15 pm ET by SVH
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
