I’m wondering what size compressor I might need to run two framing nailers at once and also if if is possible to somehow link two small compressors (i.e. 6 gal. 2 hp) onto one hose. Any ideas?
In this video, learn how hidden fasteners make for a seamless feature wall.
>>I'm wondering what size compressor I might need to run two framing nailers at once << Depends on what the framing nailers are doing - nailing stud walls together requires much less air than say sheathing or subflooring due to variations in the firing rate.
>>is possible to somehow link two small compressors...onto one hose.<< yes, an archive search will produce hundreds of discussions on this topic.
Scroll all the way down to the end of the forum, type in "two compressors" in the search box. You will probably get an old thread about "pipes" - don't panic, be patient and the electronic squirrels will change the thread soon.
Hours of reading available on this topic. Enjoy.
Jim
