Concrete basement floor slope
bclasen | Posted in General Discussion on October 13, 2005 05:44am
We have a 1950’s built house with an approximately 1,000 sq. ft. basement (25×40’ w/ a cinder wall running the length down the middle splitting the basement). We recently fixed up one side into a nice media room, I want to begin working on the other side. The unfinished side has two rooms, a bigger room and a utility room (approx. 12 x 12’).
Before finishing off the second half of the basement, I’d like to correct what I think is a problem with the floor and water drainage. I worry about water from two places – water from appliances (washing machine, water heater) and water that enters the house from heavy rains. Both these issues are in the smaller utility room – the appliances are there and we have a basement door to the outside in that room. I’m doing what I can for the appliances, such as stainless steel braided hoses w/ auto shut off. I’ve also installed a water detector that sounds an alarm if water is on the floor.
By far my biggest problem is from heavy rains. When we get a soaker (such as over the last several days), water flows down the steps where it drains through a 4-5†drain. Works fine, except when the drain gets clogged by leaves. So we keep it clean, but that doesn’t always do the trick. For example when a passing hurricane came through last year, the rain was so heavy that it picked up leaves and other debris on the lawn & sent them down the stairs, plugging the drain. Luckily I was home & happened to go into the basement & found an inch of water spreading through half of the basement. My wet/dry vac did the trick, but I worry about what would happen if I wasn’t home, especially since I’ve fixed up the basement.
The previous owner of the house put in a sump pump in the utility room in a corner. There is no other drain in the room. When water comes through the door, it covers about half the floor and spreads quickly to the adjoining room (currently unfinished) and then to the finished room. The weird thing is the floor is higher in the utility room where the sump pump hole is. So even if we get flooded, it would have to be quite deep in order for the water to drain in the sump pump hole. In the meantime, probably three quarters of my basement would be flooded.
So I’d like to do a few things, including putting a drain in front of the basement door that flows to the sump pump. But it seems to be a basic thing to do would be to get some concrete work done so the water flows directly to the sump pump in case of problems from the outside or inside (broken hose, etc.).
So my short question (after a long-winded explanation) – would having concrete work done to change the slope of the floor be my best bet? Or would some other approach be recommended?
Thanks,
Bob<!—-> <!—->
  1. rez | Oct 16, 2005 02:37am | #1
    Greetings Bob,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someones attention that can help you with advice.
    Cheers
    40,000 Americans are injured by toilets each year.
  2. DaveRicheson | Oct 16, 2005 04:44am | #2
    Where does the drain outside of the door go?
    If the water is flooding down the steps. can you change the outside grade to keep it from flowing that direction? Or, maybe even build a roof over the steps.
    If the door out of the basement is not used often, a high hat drain is less likely to glog than a flat floot drain. They are a tripping hazrard if the entrance is used a lot though.
    The best solution is to stop the water from getting in. Even an outside sump pump would work if you get the discharge far enough away from the house that it does just run back down the steps.
    Dave
    Dave
    1. bclasen | Oct 18, 2005 12:57am | #3
      Thanks for the reply - not sure what I'll do though. I can't drain much away from the stairs without building a roof over it. Problem with that is I'll have to play with the look - wouldn't blend in that well. A high hat would make sense, but we use that door a fair amount (carrying bikes up, etc.). You are right, keeping water out is the primary thing to do, but I also want to prevent a problem in case it does get in or if there's a water heater or hose failure.Thanks again,
      Bobby
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
