I want to do some concrete counter tops this winter and would like some ideas on setting up shop in my basement. I have 9″ ceilings and a large open area. It is also a walkout so getting the counter out shouldn’t be a problem. The problem is polishing the concrete, I need to get rid of the waste water and the”spoils”. I had a thought of a raised platform with plastic that tapers to a pit. In the pit there could be a piece of drain tile with filter sock, then I could pipe the drain tile to my sump and let it take care of it from there. Any other ideas would be greatly appreciated.
13 articles to help you make a new house or existing home safer from the threat of wildfires.
why not just let it fall on floor , let dry then sweep up.
Get Mongo to email you his writeup on making concrete countertops. When you do one in a gloss formica mold, and use the right techniques for mix, placement, and vibration, you'll forget about polishing.
